I am looking for the associated japanese model to German's version from Graetz, model No HSA4000 (HSA-4000) - for images go to
Graetz Amplifier Verstärker HSA 4000 | eBay
Other / GREATZ HSA 4000 ANF? HST 4000 TUNER %100 orjinal... at sahibinden.com - 146532406
GRAETZ HSA 4000 (338012530) - Archiwum Allegro
Graetz HSA-4000 Vollverstärker Verstärker kaufen - Spring Air Second Hand HiFi Shop
The only I found, that is close by this model, is the Sanyo amp model DCA-303 (DCA303) - go to
SANYO DCA 303 VERSTÄRKER SAMMLUNGSAUFLÖSUNG | eBay
Le forum de Vintage Audio Laser • Afficher le sujet - Discussion générale sur la Hi-Fi vintage (last pictures)
http://www.hifigoteborg.se/Sanyo dca-303 spec.htm
maybe also the DCA30 (DCA-30):
Sanyo DCA 30 - Wohld-Klang
The models
Telefunken RA100 und RR100 about
http://john.ccac.rwth-aachen.de:8000/telefunken/ra100/
http://john.ccac.rwth-aachen.de:8000/telefunken/rr100/
and BAYREUTH MICRO STEREO VERSTÄRKER SV281 about
ImageShack® - Online Photo and Video Hosting
Die Marke Bayreuth
are not close enough for me.
Best thanks for advices.
The informations under
http://www.diyaudio.com/forums/chip-amps/201441-stk459-replacement.html
don't provide any advices.
The models
Die Marke Bayreuth
Is the STK465 a preamp or a power stage? I'm fixing an old Sanyo DCA303. One channel is totally dead, both via headphones and speaker out, and for all inputs, with the channel's VU meter not showing any signal. I was wondering if the STK is the actual preamp (and probably bad) or I should look elsewhere...
The STK465 is a power amp with quasi complementary output stage - go toIs the STK465 a preamp or a power stage? I'm fixing an old Sanyo DCA303. One channel is totally dead, both via headphones and speaker out, and for all inputs, with the channel's VU meter not showing any signal. I was wondering if the STK is the actual preamp (and probably bad) or I should look elsewhere...
STK465 Transistor Equivalent Circuit Diagram
Check out at the input pin of STK465 whether there is a signal. If yes, this hybrid module must be replace.
Thanks, it does come up that the STK is bad. With it being in the circuit, one channel doesn't look as should on my oscilloscope. With it out of circuit, pins 16 and 1 (inputs) show correct signals. I was wondering if the STK465 sold on eBay for only a few bucks, might be fake, or if they are cheap copies which won't sound as good as the Sanyo original part?
- Chip Amps
- STK465 - in which Amplifier models in use?
