PAM8403 Amp
I love those little amps. I've built many portable units since I started this thread..
Been using 5 volt bank batteries for the power supply. The ElCheepos work better without the low current sense circuitry. The more expensive bank batteries want to shut down because the amp doesn't draw enough current to keep it turned on..
Found these little gems. Perfect for a quick Bluetooth project..
New Mini Bluetooth stereo digital amplifier AMP micro USB powered 2X3W board module free shipping-in Other Consumer Electronics from Consumer Electronics on Aliexpress.com | Alibaba Group
Try a BSC circuit on one. You'll be impressed.. ;)
http://diyaudioprojects.com/Technical/Baffle-Step-Correction-Circuit-Calculator/
