LM1875 on TDA2030 pcb /w single rail PSU
Old 25th December 2013, 06:59 PM   #1
riko4628 is offline riko4628
Default LM1875 on TDA2030 pcb /w single rail PSU
So, i got this TDA2030 kit from my grandma (Yes, my grandma ), and i want to use that pcb with LM1875: http://www.soselectronic.ro/a_info/resource/p/ne019.pdf (If you want to translate something just say)
Is it possible? What do i need to change?
Old 25th December 2013, 07:37 PM   #2
ricortes is offline ricortes  United States
Let's see if I have attachments figured out.
There are some differences between the board you have and the LM1875 data sheet for single ended power supply. The diodes in your board are there for an extra measure of protection so you should leave them in. If you are changing voltage for higher output i.e. say 40 volts, then replace the cap going to the speaker and ones on the supply to at least 50 V rating. Most of the rest of the circuit is in the ball park as far as I could see with a cursory glance. i.e. input capacitor on your board is 2.2 uF and on the LM1875 is 1.0 uF. Shouldn't make a huge difference in functionality, maybe a bit in sound quality.
Old 25th December 2013, 07:40 PM   #3
So, i don't have to change anything?
Old 25th December 2013, 11:23 PM   #4
Not if you don't use a supply voltage higher the the original board recommends.
LM1875 on TDA2030 pcb /w single rail PSUHide this!Advertise here!
LM1875 (TDA2030 2.1) grounding issue rightshoes Class D 7 9th February 2014 08:32 PM
Tda2030 vs lm1875 livenicely Chip Amps 43 17th December 2013 06:07 AM
is LM1875 replacement for TDA2030(A) drmr_bg Chip Amps 10 16th January 2012 10:55 PM
Wanted: Op-amp with single supply, 32V or more, and rail-rail capability akis Power Supplies 3 13th November 2010 01:53 PM
Using split rail supply for single rail DC DanX Chip Amps 1 15th March 2008 05:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
