Joe Rasmussen "Trans-Amp" - 40 Watt Transconductance "Current Amplifier"
Old 7th March 2015, 03:02 PM   #121
superpete is offline superpete  Canada
Hi Joe, can I use a lm3886 in the same circuit? I have 10 of them I never got to use...
Old 7th March 2015, 04:31 PM   #122
yu3ma is offline yu3ma  Serbia
yu3ma's Avatar
Here is one similar approach published in 2012, not exactly transconductance amplifier but similar in a way of wiring in order to reduce DC offset as some components in input/FB stage are removed in order to get better performance.
Wiring is very very import and need to keep it as shown on schematic.
Same rules apply and for Joe's version.
More info about this design here (use Google translate):
HQ modifikacija za TDA7294 – HiFi Audio Amplifier 5Hz – 200Khz YU3MA
Old 7th March 2015, 07:41 PM   #123
R.I.P.
Yu,
all the Signal wiring should not be taken to that star type Power Ground.
All the Signal wiring should remain close coupled Flow and return Pairs with low Loop Area.
regards Andrew T.
Old 31st March 2015, 07:46 AM   #124
kp93300 is offline kp93300  Malaysia
Default this amp compatible with markaudio 12 P
I have ordered the Lm 3875 chip .
I attached the spec for my speaker.
Is this speaker compatible ?
Do I need a dc detection relay in the out put ?
What is the range of input Voltage power that will work without changing other part value ?
thanks
kp93300
Old 31st March 2015, 08:26 AM   #125
syklab is offline syklab  United States
My friend had the PCB made for us to experience this current amp, I am using the Power supply board from PD's chipamp with a 300VA 26VAC x 2 R-core transformer and it is working nicely. I have been using it to drive a pair of the CHN70 for 2 weeks already and it sounded much better than my class D amp. No speaker protection yet, I don't think it is needed, no power on/off pop.
Old 31st March 2015, 11:16 AM   #126
Hi syklab,
Can you post a picture of the amp ?
Can you elaborate on the sound signature of the amp ?
what size heat sink ?
Any dc offset?
I have send you a PM
thanks
kp93300
Old 31st March 2015, 02:50 PM   #127
The DC is measured about 0.016V
Old 31st March 2015, 09:24 PM   #128
thiagomogi is offline thiagomogi  Brazil
Article based on Elliott
Variable Amplifier Impedance
not tested
File Type: jpg 11116137_10200334264356921_22196064_n.jpg (43.2 KB, 781 views)
File Type: jpg 11088091_10200334264276919_1235682888_n.jpg (45.7 KB, 764 views)
File Type: jpg 11121152_10200334264196917_189393995_n.jpg (43.4 KB, 262 views)
File Type: jpg 11075061_10200334188835033_1969577201_n.jpg (76.4 KB, 256 views)
Old 1st April 2015, 07:44 AM   #129
padamiecki is offline padamiecki  Poland
how does it sound comparing to pure current drive?
is there big difference?
regards, Pawel
Old 1st April 2015, 01:12 PM   #130
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
Originally Posted by AndrewT View Post
Yu,
Absolutely. I noticed that straight away.
"Elsinore Project" DIY Speaker System
"If I am not allowed to make mistakes, how will I ever become an expert?" Excerpt from a dream.
Joe Rasmussen "Trans-Amp" - 40 Watt Transconductance "Current Amplifier"Hide this!Advertise here!
Building "The Wire AMP" Class A/AB Power Amplifier" wirewiggler Solid State 13 24th January 2015 01:22 PM
"WTB" "The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral enantra Swap Meet 3 23rd December 2012 07:36 PM
That curious extra knob, or: "Trans-Amp" Duo Solid State 111 25th November 2011 12:57 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 03:29 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
