Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Chip Amps Amplifiers based on integrated circuits |
Thread Tools |
#4831 | |||
Reality first!
that loud hum was present with input disconnected (as it seems)? If so it's perfectly normal since it's a floating design, it's the input signal ground that 'grounds' the entire amp... It was so with input connected? Maybe you inverted signal hot with signal ground Quote:
Dario ClaveFremen "Bailando Salsa en el Sietch" - Book here for My_Ref Fremen Edition 15th GB |
#4832 | |
So that the heat sinks + case were connected Only to the PE of the power line input? If that is the case, I'm afraid that You have misunderstood the situation: naturally the amplifier PGND 'must' be connected to the case & heatsinks!! Than it will be connected also to the PE, for safety reasons. But exactly because of that hum, noise pickup, the case must be directly, low inductance way connected to the amp PGND point.. Always! Last edited by Joseph K; 6th April 2021 at 09:17 PM. |
#4833 |
Dario,
Thanks for the advice - I'm sure I/P connection polarity is correct, but I'll check again to make sure. And yes, very loud hum is present, and at same level, whether I/P is connected or disconnected, no difference. Joseph, Thanks for your confirmation - I followed the build guide which clearly states "The My_Ref and so the My_Ref Fremen Edition are floating designs so they’re not supposed to be grounded." I took this as being a literal advice, and so yes I did not connect PGND or HSGND to anything, so looks like my bad and my misunderstanding in that case! Circuit diagram shows both of these points connect through to GND, so I (wrongly it seems) presumed this GND would be picked up somewhere else in circuit; but now thinking about it, it must be fed from somewhere of course - which I guess is indeed the PGND connection!!! Doh! Thanks both - all now working OK in the end, which is the main thing.
Richard |
#4834 |
Richard,
Let me demonstrate, how it had been resolved by Penasa, in his original design, the MyEvolution: On the pic, that L is directly connected to the PGND part of the ground plain. ( I'm connecting to PE in a different part of the chassis, but they could be united) |
#4835 |
Thanks Joseph, of course it's all obvious to me now - and I confess to feeling a little foolish, having been an electronics engineer for all of my career before retiring!!!
Ahem ...!
Richard |
#4836 |
Hi i'm starting to build My_Ref ... cause I would like to do the enclosure by myself, I need a right heatsink.
Could someone suggest me something, please? |
#4837 | |
Reality first!
these last grounding recommendations are a bit confusing... the PGND arrangement in your pic is the one of the original My_Evo, but in Rev A Mauro replaced R81 with a wire jumper (so that PGND is tied directly to the chassis) and disconnected PE from the chassis (see page 4 of the My_Evo Rev A guide). Also Richard interpreted correctly the build guide, usually the PGND should be connected to PE via a ground breaker or, taking a small risk, left unconnected (the best sounding solution). Can you elaborate? Thanks in advance ![]()
#4838 |
Dario, "certo che si.."
You are right, but You know more than necessary.. ![]() I did not want to complicate the message with historical details. The case is that also in that amp of mine (Evo) the 'rev A' mod is executed, that resistor is jumpered (from below) and PGND ground plain is effectively directly connected to the chassis. What You are telling, that second part is also true: connecting to the PE was discussed different times before. My point of view now is connect to it. Safety reasons, law. Goes against good signal integrity, but what can you do.. Last edited by Joseph K; 7th April 2021 at 09:34 PM. |
#4839 |
Try to explain further: the chassis must be at a good schield potential, if it is floating, it behaves on the contrary of a schield, it's a bloody big antenna directly communicating with the several MHz bandwith power chips.. A well schielded case around this circuit to me, for me always had brought only positive results.
For me this amp in a case without good quality schield connection.. Is a ticking clock.. The PE, on the other hand, brings only heavy dirt and disturbs to the circuit. With the PE directly on chassis one gets assured that the dirt has a highway connection into the circuit.. But/ and not connecting the circuit PGND to the chassis - do not give any better protection, and permits this kind of strong noise interference what Richard had experienced.. For me it's a lose /lose situation, unfortunately.. Ciao, George |
#4840 |
Thanks Dario for the suggestion of R3, I have reversed it, but what do you say who knows if he will have suffered damage playing for a week? now, however, the sound has remained very beautiful, warm and transparent. I'm enjoying listening to all my favorite records, it feels like listening to a nipva version. a pleasant surprise. I'm happy. thank you
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
My_Ref Fremen Edition - Beta build/Fine tuning | ClaveFremen | Chip Amps | 1526 | 8th October 2017 03:03 PM |
My_Ref Fremen Edition RC - Build thread | ClaveFremen | Chip Amps | 1273 | 4th July 2016 06:21 PM |
My_Ref Fremen Edition - need help on PCB evaluation | ClaveFremen | Chip Amps | 450 | 23rd October 2013 03:38 PM |
My_Ref Fremen Edition Interest/Group Buy | ClaveFremen | Group Buys | 348 | 25th June 2013 09:58 PM |
Last My_Ref Fremen Edition RC boards for sale | ClaveFremen | Swap Meet | 3 | 4th December 2012 01:04 PM |
New To Site? | Need Help? |
