My_Ref Fremen Edition - Build thread and tutorial
Old 16th September 2019, 06:57 AM   #4191
freegianmaria is offline freegianmaria  Italy
Hi all.
I Need 12v inside the case of my amp My_ref to power a low noise fan: can i obtain It directory from the board? Where?
If It Is no possible can you suggest a soluzioni?
Thank you vert much for the help.
Old 16th September 2019, 12:01 PM   #4192
phase is offline phase  United States
I would suggest a separate transformer, and also to use a 12v fan at 5v, using a 7805 regulator, to reduce noise.
Old 16th September 2019, 12:13 PM   #4193
Joseph K is offline Joseph K  Hungary
I concur. Do not use, please, the local regulators for anything else..
The small transformer & regulator works very well, out friend is using like that to great effect.
Old 16th September 2019, 01:23 PM   #4194
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
+1
In the past, I have powered a separate opamp circuit requiring only a few mA stolen from the FE board. When I changed to a higher current opamp, the FE regulated power became erratic and may have oscillated. So stealing power from the FE is not a good idea from a noise stand point, but also from a power available stand point.
The nice thing is that the fan doesn't require a fancy power supply.
Good luck.
Jac
Old 16th September 2019, 03:10 PM   #4195
Ok, It seems that best solution Is 5v fan (low noise) with dedicated power supply. Right?
Old 17th September 2019, 02:43 AM   #4196
Panelhead is offline Panelhead
Also the small signal regulator circuit does not react well to a high capacitance on the output.
Cheapest is bestest
Old 17th September 2019, 05:39 AM   #4197
giupo is offline giupo  Italy
Are you sure that you need a fan? A reasonable heat sink is enough for the circuit.
My_Ref Fremen Edition - Build thread and tutorialHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
My_Ref Fremen Edition RC - Build thread ClaveFremen Chip Amps 1273 4th July 2016 06:21 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
My_Ref Fremen Edition Interest/Group Buy ClaveFremen Group Buys 348 25th June 2013 09:58 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Copyright ©1999-2019 diyAudio
