My_Ref Fremen Edition - Build thread and tutorial
Old 13th August 2019, 11:54 AM   #4161
giacintopapa is offline giacintopapa  Italy
I would like to submit these two measures to you. We have seen that at the output of a transformer preamp, as expected, there is no trace of DC, it is blocked by the transformers.
I wanted to see how much DC was present at the output of my dac. As always I don't know if I used a correct method ...
Dac turned on without signal. On the left channel I measure about 1.0 mV, on the right channel I measure about -0.9 mV.
I didn't expect to find a negative current on a channel.
Would anyone know how to explain these measures (if they are correct and have a meaning)?
Thank you all
Ciao
giacinto
Old 13th August 2019, 01:20 PM   #4162
Joseph K is offline Joseph K  Hungary
Yes it is absolutely normal, even more, your result is very good. Your dac is a correctly designed/ executed product.
Output offset can be any polarity, it's normal. Think of it that your dac is producing an AC output, with 0V DC being the center value. The actual momentary magnitude is either above or below in the time; like between +2,8V / -2,8V peak maximum, in case of an average dac output level.
Ciao, George
Old 13th August 2019, 04:20 PM   #4163
Grazie, George, e ciao
Giacinto
Old 13th August 2019, 04:36 PM   #4164
Panelhead is offline Panelhead
First, George it is so good to see you back!!!!
The dac measurement is fine. It tells me the dac is dc coupled, a good thing. Also, hook up the TVC and measure again. The dc voltage offset should be even lower when loaded by the dc resistance of the input side of the TVC.
My transformer is on the input of My_Ref. Been running some REW sweeps. Not happy with results. The transformer is raising the noise floor.
Going to play with routing and transformer position to see if there are easy fixes.
Cheapest is bestest
Old 13th August 2019, 06:27 PM   #4165
Default With plots
One saving grace is the high efficieny speakers, very low power at normal listening.
Cheapest is bestest
Old 13th August 2019, 08:33 PM   #4166
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Am I assuming correctly that the curve on the left is the Fremen only and the curve on the right is the Cinemag + Fremen? If so, a very curious result.
Is there any chance that the input ground to the transformer is common with the output ground? I'm really just guessing in the dark.
Jac
Old 13th August 2019, 10:57 PM   #4167
I see saturation in the last plot.. somebody is saturating. Is it possible that You overdrive the transformer? Or the input ADC, given that the signal is -1,6dB, with respect to the -14dB in the first.. -4dB in the second.. when you get close to the Zone, saturation sets in all at once ..
Old 13th August 2019, 11:21 PM   #4168
lehmanhill's Avatar
George,
Very good point, as usual. The transformer is good for +20 dBu, but the graphs are at -14, -4, and +1.7 dbFS. I believe that is decibels relative to full scale, so depending on what is full scale, the source or something else is likely clipping or saturating.
Jac
Old 14th August 2019, 02:58 AM   #4169
Default All graphs are using a Cinemag 15/15B line input
Just showing the overload and saturation.The low level is normal listening output. Speakers are three way horns with a sub.
The chain here was REW signal generator, Focusrite Clarett 4Pre output into a Fremen. The measured voltage across the 6 ohm power resistor is fed into an ADC on the Clarett and looped into REW.
All three graphs use the same power resistor and input transformer. High enough input really gets it ringing.
A different signal generator is next, an Akitka 79.00 generator. I hope to install Cinemag CM10/600 4:1 stepdown transformers soon and retest.
Had a pair of Lundahl transformers and configured them for 4:1 step down. Saw a lot of ringing and removed. Guess all ring if driven at a high enough level.
Cheapest is bestest
Old 14th August 2019, 01:16 PM   #4170
lehmanhill's Avatar
Interesting. As usual, I learn something new every day.
We are wandering off topic, but please report your experience. I guess a simple RC post transformer snubber wouldn't fix that ringing.
Jac
My_Ref Fremen Edition - Build thread and tutorialHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
My_Ref Fremen Edition RC - Build thread ClaveFremen Chip Amps 1273 4th July 2016 06:21 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
My_Ref Fremen Edition Interest/Group Buy ClaveFremen Group Buys 348 25th June 2013 09:58 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Copyright ©1999-2019 diyAudio
