My_Ref Fremen Edition - Build thread and tutorial
Old 10th December 2018, 11:55 AM   #4071
Joseph K is offline Joseph K  Hungary
I'm afraid there could be a misunderstanding here..
As far as I remember Dario always told: connect PGND to the case.
Now, seriously: even without loop braker - you could do a test. Just connect PGND with and then without PE connection. Without is only a temporary, transitorial test, not stable solution.
Ciao, George
Old 10th December 2018, 12:48 PM   #4072
Luca72c is offline Luca72c
That's true, and ground lift is suggested by Dario himself too, in the build tutorial you can find in the project google drive repository
Old 10th December 2018, 04:33 PM   #4073
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by wilco87 View Post
Problem is there's a lot of hum from both channels in the integrated one, probably a ground loop I cant find.
Is the mass from cinch to IN (myref gnd) and from volume to IN (on myref gnd) correct? Took that connection from the audiocreative integrated chipamp. DIY LM3886 Chipamp
See attached photos for drawing of the spaghetti mix of red wires. Still need to clean that up...
You have two ground paths, I would remove the ground wire that goes from My_Ref boards input GND to the ground bus on RCA inputs.
Also shielding (the missing of) and not twisted wires coudl have a (big) role.
Removed all the wires, selector and volume: Just the boards and output. Stil humming. I will remove the boards from the case and report back.
Wait! Did you short boards inputs during this test?
Unless connected to signal ground via a source or a preamp the amp will hum, it is absolutely normal.
The amp should be silent when connected to a source/preamp or with shorted inputs.
If with shorted inputs the amp is not silent you can:
  • double check heatsink grounding
  • rotate transformers until hum disappear
Dario
ClaveFremen "Bailando Salsa en el Sietch" - Sign for here for the 13th My_Ref FE GB.
Old 10th December 2018, 07:50 PM   #4074
Then were would Myref boards (and pot) connect to input GNDs?
Maybe i didn't understand well what you wrote...
Old Today, 05:58 AM   #4075
freegianmaria is offline freegianmaria  Italy
Ok, little confusion to me.
Only 3 question:
1) PGND must be connected to the ground or not?
2) The heatsink must be isolated from the ground or not?
3)The - of signal audio must is connected to the ground?
Thank you very much to anyone reply me.
My_Ref Fremen Edition - Build thread and tutorialHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 04:03 PM
My_Ref Fremen Edition RC - Build thread ClaveFremen Chip Amps 1273 4th July 2016 07:21 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 04:38 PM
My_Ref Fremen Edition Interest/Group Buy ClaveFremen Group Buys 348 25th June 2013 10:58 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 02:04 PM
