My_Ref Fremen Edition - Build thread and tutorial
Old 3rd December 2018, 10:12 PM   #4061
Peterma is offline Peterma  Australia
Originally Posted by Aswin2 View Post
Aliexpress is your friend.
Search: fan temperature controller
yep thanks just ordered them.
Old 4th December 2018, 05:24 PM   #4062
Aswin2 is offline Aswin2  Netherlands
I've got similar questions for the inrush limiting pcb.
Search on Ebay or Aliexpress for "soft start" and useful items will pop up.
Old 5th December 2018, 11:10 AM   #4063
wilco87 is offline wilco87  Netherlands
Hi, back with my second my_ref, but now it's an integrated version. Really like the amp, still amazed it played better than my tube...
Problem is there's a lot of hum from both channels in the integrated one, probably a ground loop I cant find.
-hum increases with volume turned up
-hum stays when inputs are disconnected
-hum stays when selector is set to 3 of the not used positions
-when touching transformers, i hear a 'pop' (softly) through the speakers, also while touching mass of cinch/input
-dc offset is 3mV on right channel, 6mV on left channel.
-music sounds already rather good, even through 7 dollar test speakers
Is the mass from cinch to IN (myref gnd) and from volume to IN (on myref gnd) correct? Took that connection from the audiocreative integrated chipamp. DIY LM3886 Chipamp
See attached photos for drawing of the spaghetti mix of red wires. Still need to clean that up...
Old 5th December 2018, 12:21 PM   #4064
Luca72c is online now Luca72c
Unshielded low level signal wires so close to unshielded 230Vac wires and input plug is not a good idea...
I don't know if that could be enough for the hum you hear, but i'll fix that anyway.
Then try using a proper ground lift (as described in the tutorial) and connecting PGNDs to ground lift chassis GND.
Old 5th December 2018, 01:05 PM   #4065
Thnx Luca, I'll try that when i have those components.
Decoupled volumepot, selector and cinch from PCB, hum is still present.
Old 5th December 2018, 11:59 PM   #4066
Panelhead is offline Panelhead
Are the inputs (RCA jacks) isolated or grounded?
Cheapest is bestest
Old 6th December 2018, 12:31 PM   #4067
Inputs are isolated from case and grounded.
Removed all the wires, selector and volume: Just the boards and output. Stil humming. I will remove the boards from the case and report back.
Old 6th December 2018, 12:54 PM   #4068
Joseph K is online now Joseph K  Hungary
Wait a minute.. it is my favourite case: You did not connect any way the board PGND references to the case. I see the PE connected to the case but the boards are floating..
This is the typical situation forced around here: all heavy attention to the safety rules - - and zero attention to signal integrity..
Sorry it's not directed to You but the general attitude..
Ciao, George
Old 6th December 2018, 01:09 PM   #4069
That is, to be very clear: these amps are high speed solid state devices. Easily go to the MHz region in their usable bandwith. They have to be treated as such. They are not Toobzz!
For any kind of sensitive high speed electronics : shielding is an all important element.
The case cannot be floating antenna receiver closely coupled to the sensitive parts (like high impedance input pins of LM3886 <> heatsink)
The case must be connected with low ! Inductance, short thick conductor to the metal case / shield & heatsink.
PE earth connection is for safety. It is in clear collision with signal integrity requirements, and would need extra care to resolve properly.
Ciao, George
Old 10th December 2018, 11:40 AM   #4070
Ciao, George
Hi George, thanks for the tips. Just to be sure, do you advise the same as luca (loop breaker, heatsink connected on zero volt Line)? This breaks the floating design Dario proposes, but listening to that hum is quite a challenge.
The heatsinks seem to be the source of the hum. Just with one channel installed, without anymore extra wires the hum remains.
Hopefully the stuff for the loopbreaker will be here at friday.
My_Ref Fremen Edition - Build thread and tutorialHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 04:03 PM
My_Ref Fremen Edition RC - Build thread ClaveFremen Chip Amps 1273 4th July 2016 07:21 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 04:38 PM
My_Ref Fremen Edition Interest/Group Buy ClaveFremen Group Buys 348 25th June 2013 10:58 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 02:04 PM
