My_Ref Fremen Edition - Build thread and tutorial
Old 17th July 2016, 08:18 PM   #2591
ggerla is offline ggerla  Italy
Default Problem with one channel
Hi all
this evening I try to do some test on my new build with wave generator and oscilloscope.
One channel seems ok. Put 200mV at 1KHz and obtain 2V. There is a lot of noise but problably depends on connection...
The second channel doesn't work. If I put some wave in input I have a distorted output and often the led goes off. Probably he go in protection mode.
I welded both channel in parallel...
Can you help me?
Old 17th July 2016, 09:35 PM   #2592
Originally Posted by ggerla View Post
Hi all
Can you help me?
It seems that there is a signal to high frequency with gigh voltage (more that 2V) at input of lm3886 (pin 10).
I'm not able to understand where this signal is genearted because when I put the probe on one pin (R12, C34, lm3886 pin 10) protection go on.
Old 17th July 2016, 10:14 PM   #2593
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Can you help me?
Post some good quality pictures, please.
Let's see if there's something wrong.
Did you clean boards?
Did you take the indicated measures?
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 18th July 2016, 09:12 AM   #2594
xcj999 is offline xcj999  Austria
troystg: yes plenty of space. Wanted to keep the option for 4 channels open. And the price difference for smaller cases is negliable anyway
dario: yeah, especially R12 since you put it up so high on the modding list *ggg* Ah, well ... first finish volume control and dac, then i have earned some more money for z-foil
rookie: well let me try. Its hard to do an AB comparison since I also modded my speaker crossover after building this amp. I used a yamaha ax-496 with Infinity RS 5000 speakers.
The first big difference i noticed was the soundstage. It really made it sound like the music was not coming from the speakers anymore. Very good separation and placement. Also, it definitely has this "tube-touch" not as extreme as with a normal tube amp, but to get an idea what it sounds like a very good picture. The voices now sound a lot more realistic to me. Now i sometimes hear a noise and only afterwarsd realize it was from the recorded music/movie *ggg* In my eyes a really worthwhile build with incredible bang for buck ( aaaand i went some 200 eur over budget since this was my first build and i needed to buy lots of tools and decided to go for some upgrades - so beware ;-) )
a general question - any of you has any experience with shielding? The amp is super robust and doesn't mind, but my dac seems to picks up EMI from lightbulbs(halogen) and the fridge. I do use a line filter before the psu, so i assume it comes from EMI, not over the power line. What materials would you suggest? mumetal?
Old 18th July 2016, 09:18 AM   #2595
R.I.P.
Originally Posted by xcj999 View Post
........... my dac seems to picks up EMI from lightbulbs(halogen) and the fridge.
Sort the fridge first. Fit a mains snubber across the motor, or replace the faulty one. It is always better to sort interference at source. The regulations require source to be properly RF attenuated
Halogen lights are just resistors. They produce VERY little emi.
Your problem is more likely to be the SMPS used to convert mains 220/240Vac down to the 12V required by the resistive filament.
How many smps do you have? Is it worth replacing them with current emi compliant versions?
regards Andrew T.
Old 18th July 2016, 09:33 AM   #2596
Sort the fridge first..
thanks for the quick reply. The problem is, that the fridge belongs to our landlord, so i shouldn't do any mods i can't make "invisible" in case something goes wrong with the fridge. Its pretty new and a solid brand, so I am surprised about the interference.
oh, good to know. It's only one SMPS. It seems to be built into the shelf with the lights. Have to check if I can access it.
The wierd thing is, when i first put the dac in the new case, the interferences stopped. But thinking of it, I did change the wire length of the dac psu to the dac. Could maybe 5cm more length of the dc power lines be the reason for this?
Old 18th July 2016, 06:40 PM   #2597
In attach photo. Let me know if it is enough...
Old 18th July 2016, 07:52 PM   #2598
OK
probably I found the problem I have inverted db139 and bd 140...
Old 18th July 2016, 10:09 PM   #2599
Reality first!
I'm happy that you found the problem.
Replace also both zeners and it's not a bad idea to replace also the LM317s.
LM318 and LM3886 should not be affected.
Dario
Old 22nd July 2016, 04:01 AM   #2600
ghiglie is offline ghiglie  Italy
My build will stop again, I'm being in Milan and Turin till next Wednesday. I managed to solder Amtrans on one side - too late for asking, but if C32 goes reversed, printed side of Amtrans' goes on same side, right? Wish I'd have taken a picture...
My soldering struggle is still on, seems my iron suffers working at high temperature and sometimes it "misses it", while the wire I'm using needs it really. Hope I haven't burnt the Amtrans...!
So, I'll order 50g of Oyaden, just found a cheap eBay seller from Spain.
Inviato dal mio D5803 utilizzando Tapatalk
My_Ref Fremen Edition - Build thread and tutorialHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
My_Ref Fremen Edition RC - Build thread ClaveFremen Chip Amps 1273 4th July 2016 06:21 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
My_Ref Fremen Edition Interest/Group Buy ClaveFremen Group Buys 348 25th June 2013 09:58 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
