Contest:  Linear Power Amp in a mint tin (class Aa, class AB, or class B)
Old 26th November 2012, 08:56 PM   #101
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by keantoken View Post
. . . they don't store so much energy in their junctions.
Like FJPF5200/FJPF1943 pairs?
Old 26th November 2012, 09:04 PM   #102
littlerick is offline littlerick  United Kingdom
Wow... Just priced up parts for the tda4935 and they roll in at a huge 5 including postage.
Now if the bank of wife allows it, I will see if it will all fit in a tin somehow... Can i use normal RCA input and output, kinda like a super micro, micro amp. I have a toriod that gives 18v after rectifier so all i need is a tin and a fiver..... Sorry it may not be as technical as you guys are used to, but i dont have a clue how it all works, i just have a go and see If i never post again... it went BAD!... real bad lol.
Old 26th November 2012, 09:13 PM   #103
keantoken is offline keantoken  United States
keantoken's Avatar
Those are better, but AFAIK the MJLx302/x281 are the best in this category. The important parameter is not Cob but Cib. In the SPICE models it's Cje. Also Cbe. You want Cbe/Cje/Cib to be as low as possible for an output transistor. The actual size of Cbe is in the nF's. It is interesting to compare Cje in SPICE models you know are accurate.
Also, it is not the Ft at excursions that matters for crossover behavior but the Ft at Iq. I try to go for outputs with an Ft of over 20MHz at 100mA.
Cbe can also matter for small-signal transistors. Too much Cbe in the input stage will create a "glass ceiling" in amplifier BW that is not obvious. The BC5xx, MPSA18, 2N5210/5089 transistors have low Cbe. High-voltage transistors (japanese or not) tend to have larger Cbe and can actually lower BW if put in place of the others. So I shall proverbialize: Don't use high-voltage transistors for low-voltage applications.
Quasi-saturation and Vcesat are other parameters that get worse with higher Vcemax.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 26th November 2012, 09:18 PM   #104
bigwill is offline bigwill  United Kingdom
I'll try to use suitable output transistors but this is going to be an amp in a tin after all.
Old 26th November 2012, 09:35 PM   #105
keantoken's Avatar
It is not necessary for a working circuit but I think it is necessary for a well-behaved one. I suggest the MJE150xx pair - Cordell has models for them - which are faster than the pair Dan mentioned and more suitable for a tin-size amp.
Old 26th November 2012, 09:39 PM   #106
The MJL/NJL might be overlarge. I think that the MJW/NJW are slightly smaller. Onsemi didn't seem to have much in the way of extra nice to220 outputs, however. . .
Can sturdy drivers be output devices for a little amp?
MJE15028/MJE15029
MJE15030/MJE15031
MJF15030/MJF15031
Edit:
I see that Kean mentioned them 4 minutes ago.
Edit2:
However, I wonder if the much lower voltage Tip31a Tip32a would be lower loss, more placid (easier for stable), and cooler running?
Old 26th November 2012, 10:04 PM   #107
Originally Posted by littlerick View Post
Wow... Just priced up parts for the tda4935 and they roll in at a huge 5 including postage. Now if the bank of wife allows it, I will see if it will all fit in a tin somehow... Can i use normal RCA input and output, kinda like a super micro, micro amp. I have a toriod that gives 18v after rectifier so all i need is a tin and a fiver..... Sorry it may not be as technical as you guys are used to. . .
I'm also doing a chip project, just as basic as possible and barely meeting the 9w+9w parameter. Since mine is for use with the computer, I'm thinking of installing 1/8" stereo jack so it is really easy to fit in the tin.
Old 26th November 2012, 10:53 PM   #108
keantoken's Avatar
Originally Posted by danielwritesbac View Post
Edit2:
I don't know why that would be the case. The TIP transistors are very old, they must be a different process. I would save them for lightbulb flashers when better types are easily available.
Old 27th November 2012, 09:23 AM   #109
To be fair - with the TIPs in place, in real life, I was able to get a decent looking 100Khz sine wave at full amplitude without much trouble. Even with no bias it still looked fairly decent.
Old 27th November 2012, 04:28 PM   #110
Probably, the MJE15028/MJE15029 (or little FJPF5200/FJPF1943) could give some very good (lower noise) performance in the no bias setup. I think they're worth a try. One of the projects here in the chip amp forum uses 5200, 1943 pushed by a TDA729x chip and I think those outputs are used without bias. It seems that the negative feedback was enough for noise reduction from such fine outputs? I don't quite know the particulars.
Contest:  Linear Power Amp in a mint tin (class Aa, class AB, or class B)Hide this!Advertise here!
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 77 17th February 2019 05:07 PM
Cannibalize a Class AB Stereo to Class A Mono block. owenhamburg Solid State 8 13th September 2010 08:55 PM
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Help! 50w Class A or 150w Class AB debate Toobstheway Solid State 12 17th September 2007 07:05 PM
Copyright ©1999-2019 diyAudio
