Anywhere. My intagrated chip amp that I posted pics of a couple months ago ened up having a bad cap. I have hunted high and low, but I cant find one. I can get 1000uf all day, but 1500 is like looking for the golden goose. Is this not a common value? Theres 1 parts store in town but they are never open. Should I just pull the remaining 3 1500's and replace them with 1000's, or up them to 1 3300 per channel since there are 2 1500's per channel ?
JCoffey said:Should I just pull the remaining 3 1500's and replace them with 1000, or up them to 1 3300 per channel since there are 2 1500's per channel ?
Depends where they are located in the circuit.
Strange, 1500µF caps are easily obtainable here since it is a common value.
Did you try Digikey? Or Farnell?
Farnell InOne Export
Canal Road
Leeds
LS12 2TU
UK
Tel: ++ 44 (0)870 1200 208
Fax: ++ 44 (0)870 1200 209
eMail: export@farnellinone.com
or www.digikey.com
http://www.digikey.com/scripts/us/dksus.dll?Criteria?Ref=47308&Cat=30474934
/Hugo
Maybe someone near you is friendly enough to send you one?JCoffey said:Ya, I can order them from Digikey, but for just a cap?
I'd be willing to do it, I have plenty of them, but sending one to the States? Hmmm...would be costly.
/Hugo
No I dont have a schematic, although I wish I did. I was hoping that someone looking at it could tell me if it's paralell. I'll have to look close at the traces on the board. I have a stupid question. I have 2 Solen 400v 3.3 uf caps. Could these be used? I know they're different types, but would it work, or am I an idiot?
- Chip Amps
- Grrr, cant find a replacement 1500uf 35v cap!!!!!!
