Hum on TDA7294
Hum on TDA7294
Old 21st July 2019, 08:59 PM   #51
santitrucco is offline santitrucco  Argentina
IF the Tda7293 chipamp , when is working.
If the heat sink temperature goes up a bit, just a little, would it be okay?
Sometimes I have to touch it twice to see if it's lukewarm?
Also are both TDA in the same heatsink of 15cm x 15cm, without cooler.
Old 22nd July 2019, 01:33 AM   #52
PRR is offline PRR  United States
PRR's Avatar
It may be OK.
How does it *sound*?
Old 22nd July 2019, 02:31 AM   #53
In a few days i could tell you.
I am finishing the speakers.
One FaitalPro 3FE25 and a one SBAcoustics 3/4 dome tweeter each channel.
I think is a good speaker for listen the TDA7293 and know how its sound.
Hum on TDA7294Hide this!Advertise here!
does some know how to build a 60hz hum Eliminator which stops the 60 hz hum?? prorms Solid State 21 13th August 2011 07:26 PM
Airpax hum/shielding against hum planarboy Analogue Source 6 9th November 2008 11:30 PM
TDA7294. . . help! ;) danielwritesbac Chip Amps 3 19th April 2008 06:58 AM
Help with hum small hum problem... Guiness Tubes / Valves 10 5th May 2003 04:23 PM
Copyright ©1999-2019 diyAudio
