The Voltage-Regulator-Chip Amp family welcomes a new member:
Old 11th September 2019, 01:05 AM   #11
pelanj is offline pelanj  Czech Republic
I tried to re-arrange for single supply. Does it look OK? I am pretty sure that this could be improved. The coupling caps intentionally limit the bandwidth as I would like to try this with MF/HF horns.
Old 11th September 2019, 03:10 PM   #12
sgrossklass is offline sgrossklass  Germany
You mistakenly made R2 a 4.7 ohm instead of R8. Should be the other way round.
I don't think C1 = 1µ is a good idea, it would upset current sharing at lower freqs. Not a conventional signal path coupling cap, this one. Change C4 instead.
R31 should have at least 10 µF in parallel, 47 µF would be better.
Old 11th September 2019, 03:38 PM   #13
Elvee is offline Elvee  Belgium
Elvee's Avatar
As Grossklass said.
here is the corrected circuit:
. .Circlophone your life !!!! . . ♫♪ My little cheap Circlophoneİ ♫♪
Electrify your daily life!!! ....⚡⚡ ELEKTRIA ⚡⚡
Old 11th September 2019, 09:10 PM   #14
Thank you both for corrections!
Old 11th September 2019, 10:17 PM   #15
Elvee, I still have one question - is there any reason why the output capacitor is placed like it is on your drawing? This way, there would be DC potential at the speakers terminals - or am I wrong? I use Speakon connectors, not banana plugs, but still this makes me feel a bit unsafe (for the amp, not for me).
Old 11th September 2019, 10:41 PM   #16
Mark Tillotson is offline Mark Tillotson
R4 needs to be 4.7 ohms, remember...
Yes, normally the coupling cap is before the speaker, it won't affect performance, just look unprofessional!
Old 13th September 2019, 08:59 AM   #17
Elvee's Avatar
In fact, I started by redrawing the circuit with a capacitive virtual ground, driven by the DC level of the amp, but I realized I was going to gain nothing and I changed my plan to a more conventional solution -and I left one of caps where it stood-
Electrically, it works identically, but for a practical circuit, it should be on the output side.
Again, some reminders:
-This is not a complete amplifier, just a precision unity gain buffer; to build an amplifier, you need to add a voltage amplifier in front (opamp.... )
-R2 should be halved for regular 317's: the models I used in the sim only have half the capacity
-This is a class A circuit, meaning a high quiescent current and dissipation.
The heatsink(s) should be dimensioned accordingly.
Fortunately with regulators, if the cooling is insufficient, they go in protection mode and shut down
Old 13th September 2019, 01:16 PM   #18
I actually need a unity gain buffer, my source is 2 V RMS and the DSP can boost it to 3 V RMS and that is more than I need for my 110 dB/W horns. I will actually try to reduce the voltage and maybe halving the resistor will not be necessary at all, since 1 W into 8 ohms is my goal. I have some heatsinks ready since I want to evaluate this circuit together with the single MOSFET followers, resistor, choke and CCS loaded.
Old 13th September 2019, 06:01 PM   #19
Elvee's Avatar
For 3V rms into 8 ohm, a 3.3 ohm resistor should indeed be sufficient, and the supply can safely be reduced to 18V, maybe less.
This will seriously ease dissipation concerns.
With a reduced supply voltage, it might be useful/necessary to scale R1 & R5, to 150 and 27 ohm for example, to keep a sufficient slewrate
The Voltage-Regulator-Chip Amp family welcomes a new member:Hide this!Advertise here!
And now, the Regulator-Chip JLH Amp. Elvee Chip Amps 20 14th April 2015 09:57 PM
tube voltage regulator error amp nhuwar Tubes / Valves 14 20th May 2008 11:38 PM
LT1083/84/85 linear regulator family: what's the output voltage range? jarthel Parts 6 26th July 2007 03:53 PM
some questions about switcher regulator (LM267x family) from National jarthel Power Supplies 27 27th August 2006 03:58 AM
Copyright ©1999-2019 diyAudio
