High-end preamp for my GC
Skmenon,
I see you used those convenient looking mid size proto boards from Sim Lim. Beware the substrate is very soft, must be sort of a cardboard mix, not glass fiber. I once built a circuit with OPA627 on one of those and got oscillation despite usual decoupling. I believe they are so soggy (especially in SG) that parasitic conduction / capacitance can mess things up easily.
I'm back...
To haunt you.:D
Guys, I'm sorry, I've been out for 3 months, working and without any chance to come here.
Not much time now too, but I'll try to read the thread from where I left.
Note: I've done plenty of things meanwhile, but my pre is still the same.:)
And that means something.
:angel:
Ok guys, I'm reading the thread now, give me some time...
protos said:
My experience is that it sounds better even when driving pwer amps.I am currently using the PPA headphone amp with four paralleled buffers per channel as my preamp.I thought that one buffer would be enough for preamp duty (250ma per buffer) but when I started adding buffers the dynamics went thru the roof - huge difference.Made the gainclone sound like a kilowatt hi-end amp with no smearing or lack of finesse.
:eek: :D
Protos, you're challenging me.:cool:
Someday I may try it.
That's a macho man pre.:D
Dr.H said:
Finally built the second channel and applied the mods-
All I can say is that if the GC was a great DIY discovery, this pre is equal in impact! Soundstage is amazing-This is the best I have heard and considering the small outlay, this is the best bang for buck DIY can provide. Music is simply delicious...You actually listen to a musician communicating now-not just information but emotion. :bawling:
Carlosfm was right on the 200pF cap-it cures some edginess-Seems it may be worth playing around with.
A strongly recommended upgrade to the GC! Thanks to Pavel Macura and Carlosfm for introducing the delights of this beautiful device. :att'n: :bigeyes: :D
Rest of system: Proceed PDT3, Theta DAC, NIGC, Royd doublet speakers
Ryan
Hi Ryan!
I'm so glad you made it!
Your words tell me:
1. You've seen the light.:cool:
2. I'm not mad, I was not hearing things, your words remind me my enthusiasm after listening to my pre.:angel:
3. It shows that you know how to LISTEN.
4. I always said that the GC (be it IGC or not NIGC) works better with a good pre.
It seams that Peter Daniel has found out this too recently, so he has seen the light too.;)
Yes, this is really a special thing.
One of these days we might join the people that built this pre and drink some beers (including Pavel, of course).
Note: The 200pf cap is the final touch that makes this pre ULTRA-HIGH-END.
:angel:
I've made a PCB layout (continuesly modifying it, though), but I haven't buildt it yet (exams :( ). Currently discussing it here.
Current status:
Hi Alcaid,
Some comments on your BUF pre,
This is probably splitting hairs but ideally the current charging
the main reservoir caps C11,12 should not be conveyed by tracks passing right underneath the opamp
If however you plan to do a copper pour on say the top layer connected to GND then you might get
away with routing only +15, -15 on the bottom layer below the opamp
This sed I still believe that you could gain from supplying power from the BUF's side of the board and
moving C11,12 to either side of the BUF so as not to increase the distance between the opamp and the BUF
I hope this helped
skilpad said:
Hi Alcaid,
I hope this helped
Don't know if I understood you correctly, or you understood me. The red layer is the top layer, and it is a groundplane. The blue is the bottom layer, and it only contains V+, V- and signal routing.
carlosfm:
Thank you,
I built one of these (opa627 + buf634, gain ~10)
I have tested the preamp, and it sounds great. But, it sounds even better without the buf634 :D Maybe this is because I dont need the buf, when my preamp is close to my poweramp, or some other cause. Also tried it with headphones, and it sounded great too.. havent tried headphones with only opa627 yet, but someday I will..
