I was reading back to your post in the PSU beginner's guide thread, and you stated you had 0.5V on your output. If you had no input connected, that is way too high, probably the reason for your turn off thump. You should have no more than 0.1V (100mV) on your output, or you risk damaging your speakers. You said you got things figured out, was this problem solved too?
- Chip Amps
- Chipamp is too quiet.
