Alpine 3545 (alpines best) problems
Old 2nd January 2005, 06:19 PM   #1
DerekB1 is offline DerekB1  United States
Send a message via AIM to DerekB1 Send a message via MSN to DerekB1 Send a message via Yahoo to DerekB1
Default Alpine 3545 (alpines best) problems
Here is the problem... I have tried 2 different cd players, 2 different RCA's and 2 different cars so I know its an amp problem. What happens is that after volume 10 on the cd player the amp cuts every 5 seconds, it playes fine and sound is amazing but when it cuts every 5 seconds it gets very annoying. Please help, this is an awesome amp and I want to hold onto it for a long time.
Thanks,
Derek
Old 7th January 2005, 04:14 AM   #2
EnvisionAudio is offline EnvisionAudio  United States
EnvisionAudio's Avatar
Several things go wrong in these amps.
1) There is a thinnish ground connection to a screw terminal that grounds the heatsink. Sometimes this ground connection burns out and must be jumpered. Without the connection, the power supply secondary sense circuit (say that 3 times fast) has an unstable ground reference and will pulse the supply at a particular current draw.
2) Solder connections at the emitter resistors are cracked (happens mostly with Pioneer, but sometimes Alpine).
3) Solder connections at the Toroid or Inductor filters are cracked.
4) UPCXXXX IC driver is momentarily sending the amp into protection. I can't recall the number at the moment, but it's a heatsink SIP IC that drives the output transistors. These go bad on a number of occasions and must be replaced. There is one of these per channel.
5) All of the above, or something completely different.
Old 8th January 2005, 05:58 AM   #3
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Default Alpine 3545 Driver Chip
I believe the audio driver chip is NEC's uPC1270h. This seems to be the standard driver chip for all Alpine chips of that era.
Having owned a boatload of Alpine headunits, amps and EQs over the years, I have seen inside alot of the, and this appears to be the trend
Alpine 3545 (alpines best) problemsHide this!Advertise here!
old alpine 7903e pre amp hu problems weesatron Car Audio 38 30th December 2008 12:06 PM
Have anyone played with Alpines Ainet functions? FE3T Car Audio 0 14th September 2008 12:24 PM
is this an alpine amp? jol50 Car Audio 30 29th April 2008 04:11 AM
Alpine MRV-F400 op amp problems? spooney Car Audio 8 27th November 2007 04:15 AM
PPI vs. Alpine smokeaway Solid State 2 28th August 2005 11:51 AM
