Is there someone who has found an alternative output fet driver transistors for the Audison SR1Dk?
They use 2sb1236a/2sd1857a originally, but those are hard to get.
The supply voltage from collector to collector of the drivers seems to be only about 20v (confirm). If so, there should be many drivers that would work.
