B2 MA 6000.1
Emitter is supplied by a 5V Zener,
collector to pin 6
Base and collector are bridged with a 100K resistor, and goes over another resistor to a diode to each driver.
Behind the diode i have 6V, after the diode 2V.
Somehow the 2V musst be suppressed. I will remove the diode to the driver, to check if there is something leaking.
If i open pin 6 again, i have 5V at the Base.
Pin6 on the maiboard goes to two resistors in series, with a ceramic cap paralleled.
Than it goes to a J111 Drain..
How does it works? Should it pulled down from the mainboard? It seems, that on the drive board everything is ok.
Here is a picture from that circuit
I replaced the old diode back. Heating up the area and testing was good. No Protect anymore.
For the people reading this:
I called B2, they normally mount a fan in front of the drive board to get rid of this problem. Drivers are 2092s.
The 10uf Cap makes the problem. If heat up, it starts leaking.
