Hello!
I have a small Genesis SM60 amplifier, I somehow short the ground wire to the power cable terminal. The amplifier fuse went out and it didn't turn on.
I found out that power and output transistors went out along with the 47 ohm resistors.
Installed new IRFZ44Ns(4) and TIP147/142(2 each), amplifier is running hot and still blowing the TIP147/142 after half an hour of running.
What am I missing?
Thanks.
What am I missing?
Thanks.
I have attached few pictures. I think, I installed wrong resistor. It has to be 47ohms.
The gate resistor is more likely 47 ohms than 47k ohms.
This would not affect the output transistors. I don't see anything that looks like new heatsink compound. Did you remove the old compound from all of the heatsink mounted components (including the insulators) and applied new compound before reassembly?
- General Interest
- Car Audio
- Amplifier blowing the Power & Output transistors.
