Hifonics BXX4000.1D
Hifonics BXX4000.1D
Thread Tools
Old 23rd July 2021, 08:53 PM   #1
RJohns777 is offline RJohns777
Default Hifonics BXX4000.1D
Working on a Hifonics BXX4000.1D. If I let it sit for a long time and power it up, It comes on and runs fine. If I turn it off and back on it goes into protect right away. I can bleed the rails all the way down. No change. Goes into protect. No input signal to the output driver board. No rail. Just in protect. Let it sit for a day and it will power up and run. I looked at mnhiphop101's post. This one is not doing the same thing.
Sencor SC61, Tektronix 2213A, Fluke 87iii, Fluke 8024B, B&K E-310B W/Grounded RCA Shields, Weller WD1, Tenma 21-8220 Desoldering Tool, Tenma 72-7655 Power supply, Vista XXX-R Power supply, Sencore PA81, 8582D Hot Air Rework Station
Old 23rd July 2021, 09:26 PM   #2
Perry Babin is offline Perry Babin  United States
Is the rail reaching target voltage before the drive ICs start oscillating?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 23rd July 2021, 10:08 PM   #3
I have to let it sit now. I will check those when it powers up. But when it powers up it runs fine. Turn it off and back on stays in protect. I assume the input signal to the driver board is the center pin. Most are.
Old 23rd July 2021, 10:13 PM   #4
The center is likely ground. The input goes directly to an inverting input of the TL072.
Old 24th July 2021, 02:18 PM   #5
mnhiphop101 is offline mnhiphop101
I had this exact same issue. Connect a jumper wire from the battery negative to the negative speaker terminal and see if that allows u to turn it off and on
Perry's Guide ☆ Hantek DSO5072p ☆ Scope Plus 440 ☆ adjustable iron/ hot air gun ☆ Soldapullt DS017 ☆ 15v 40a current limiting PS ☆
Old 24th July 2021, 02:23 PM   #6
If u check the the drain on the low side u will notice the moment u let off the remote it jumps to somewhere around 30vdc. I havent been able to figure out why but connecting the main and audio ground worked for me. If u flip the board over the speaker negative is right next to the ground plane. I just used a small piece of solder braid to connect them.
Old 24th July 2021, 02:28 PM   #7
I believe u do have the same issue. Dropping the rails down wont take it out of protect. U have to let the voltage on the drain of the low side go back to zero before it will power up again. On its own it can take 10min or longer
Old 10th September 2021, 03:36 PM   #8
Thanks mnhiphop101, Just got back into this amp. Yes attaching a jumper from speaker negative to power ground allows the amp to power on and off as it should. Thanks.
Old 10th September 2021, 04:34 PM   #9
With nothing connected to the amp, what's the resistance from the primary to the secondary ground?
Old 10th September 2021, 06:32 PM   #10
About 4.3Meg ohm
Hifonics BXX4000.1DHide this!Advertise here!
Thread Tools
Hifonics BXX4000.1D mnhiphop101 Car Audio 32 25th July 2021 12:28 PM
Does the hifonics thor VII & VIII use the same rail switching as hifonics zeus VIII coomaster1 Car Audio 5 8th May 2015 04:59 PM
Hifonics Zeus VII amp or Hifonics Zeus VIII amp coomaster1 Car Audio 15 11th May 2014 09:58 PM
Hifonics ODIN VI and Hifonics CYCLOPS VI seankane Car Audio 5 1st December 2013 07:23 PM
Hifonics Cupid Lasse- Car Audio 3 5th February 2004 10:28 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
