Normal polarity is: HCPL3180 high side Black probe on Pin5 and red probe on Pin8
*High side Optocouplers in the board:*
-Good board normal polarity. Starts with 1Kohm, then rises to 6Mohm, then slowly sinks to 0.597Mohm
-Bad board OL
Probes reversed polarity.
-Good board sticks at 248Kohm
-Bad board sinks from OL to 18.5Mohm
*High side optocouplers out of the board*
Board vias good polarity:
- bad board, Starts with 1Kohm, then rises to 30Mohm, then slowly sinks to 3Mohm
- good board, starts with 1Kohm and rises to 25Mohm
Board vias reversed polarity:
-Bad board, sinks down from 40Mohm to 6Mohm
-Good board, sinks down from 40Mohm to 20Mohm
HCPL3180 out of the board, all measurements between Pin5 and Pin8 rode OL
-Bad board OL
What a stupid driver boards.
I ordered the FOD3120 you mentioned, and yes! It fixed the bad driver board.
Putted the good HCPL3180 back in the good driver board, now that board has the excact same issue.
The good board even blew the 2D driver transistor.
So, again changed the driver transistor, LM219, putted in a 100% good working HCPL3180 and FOD3120 insteas. still the same issue.
This time, only the high-side fets get hot
The FOD3180 arrived.
I soldered in a new MMBTA92 driver transistor on the driver board, new LM219, new FOD3180.
Amplifier does not startup properly and pulls a lot of current.
Only the high side fets get hot and both High and low side fets are not driven properly.
The duty cycle seems about 7-10% when pausing the scope screen.
Input square wave to the driver board is clean.
- General Interest
- Car Audio
- Audison SR1Dk output driver card, no High-side output
