Rockford Fosgate Power T2500-1bd
Thread Tools
Old 28th May 2021, 07:06 PM   #1
RJohns777 is offline RJohns777
Default Rockford Fosgate Power T2500-1bd
Hi, working on a RF Power T2500-1bd. Power supply is running. No shorts in the outputs. I have +142V rail. I don't have the minus rail voltage. I have 160 AC to both negative rail diodes CR2 and CR1005 but +24 v on the cathodes. I pulled all the outputs just to make sure they weren't a problem. Anyone familiar with this amp that can give me some ideas. Called Rockford. Schematic not available.
Sencor SC61, Tektronix 2213A, Fluke 87iii, Fluke 8024B, B&K E-310B W/Grounded RCA Shields, Weller WD1, Tenma 21-8220 Desoldering Tool, Tenma 72-7655 Power supply, Vista XXX-R Power supply, Sencore PA81, 8582D Hot Air Rework Station
Old 28th May 2021, 07:18 PM   #2
caraudioguy2100 is offline caraudioguy2100
When you measured rail voltage did you measure between the middle legs of the rectifiers?
Thatís how you test rail voltage in these amps
Multimeter:Klein Tools MM6000 Hakko FX-888D soldering station Hakko FR-300 desoldering gun dual channel oscilloscope 2 ohm 100 watt resistor Pyramid 40 amp power supply and a kenwood KDC-248U fornsiganl source . M02020 Testoscillator
Old 29th May 2021, 08:30 PM   #3
Perry Babin is offline Perry Babin  United States
As was suggested above, you have to measure the rail voltage between the output legs of the rectifiers. There is no positive or negative rail. There is only one rail and it's switched up or down as needed for the output stage.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 8th June 2021, 07:51 PM   #4
Just got back from vacation. Measured between diodes and have 137.4 volts. So I guess all that is fine. Now to find out why I have no output. I don't guess anyone has a schematic for this amp. Called Rockford they said not available for release yet.
Old 8th June 2021, 09:58 PM   #5
Anyone familiar enough with this amp to answer a question for me. I think the amp is muted. I have what looks to be input on pins 2 and 4 of U2000 and U2002 but no output on pins 5 and 7. I have 6.8 volts on pin 8 of both chips. I believe this to be bd mute. I'm using a schematic for a Power T5001bd. Can't find where bd mute originates. Can anyone help?
Old 9th June 2021, 05:54 AM   #6
On that diagram, U4-D is the mute output.
Do you have all of the various supply voltages?
Do you have audio reaching the output driver board?
Do you have rail-rail oscillation on the output transistors?
Old 10th June 2021, 12:40 AM   #7
"On that diagram, U4-D is the mute output." Yes found it on the amp power supply driver board. U101
"Do you have all of the various supply voltages?" I have rail voltage. +/- 15 volts. The schematic shows regulators for various voltages. I don't see regulators on this board. So I don't know about the other voltages.
"Do you have audio reaching the output driver board?" Yes
"Do you have rail-rail oscillation on the output transistors?" Please explain how to check rail to rail oscillation with only one rail.
Old 10th June 2021, 03:49 AM   #8
See attached for the regulators.
Do you see anything other than straight DC on any of the output transistors?
The Rockford amps are a bit different, compared to other class D amps but this is basically R-R oscillation:
bcae1.com - Car Amplifier Repair Tutorial - The Basics
Old 10th June 2021, 08:51 PM   #9
Q2010 - B +11.18, C +13.55, E +11.75
Q2012 - B +11.18, C +13.64, E +11.76
Q2000 - B - 6.28, C -24.58, E -6.85
Q2001 - B +6.26, C +13.5, E +6.85
Pretty much straight DC on outputs.
No Rail to rail oscillation that I can see.
Old 11th June 2021, 03:31 PM   #10
How many high-frequency pulses (50kHz-100kHz) do you have on the header pins of the output driver board?
Rockford Fosgate Power T2500-1bdHide this!Advertise here!
Thread Tools
Rockford Fosgate t2500.1bd problem boot35 Car Audio 20 11th December 2020 04:31 PM
Rockford Fosgate T2500-1bd caraudioguy2100 Car Audio 97 17th May 2020 07:38 AM
Rockford T2500 - 1BD Albis2985 Car Audio 152 21st February 2020 12:12 AM
Rockford Fosgate T2500-1bd in YELLOW PROTECTION Sebastian Bussanich Car Audio 11 11th January 2020 03:31 PM
Info for Rockford Fosgate T2500-1bd shawnmarsbar Car Audio 4 18th August 2019 05:54 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
