JL Audio G-MAX 1200 Replacement part
That's only for 1/2 of the output drive. Does the other half look the same?
When the outputs were heating up, were all of them heating up or were only half of the FETs heating?
Just for the record, if you simply pulse the remote on for a second and then remove it, does the drive circuit function for 10-15 seconds after remote is removed?
The amp plays clean audio, and it seems, not heating up us much... Ok, this amps new for me.. High idle current, mosfet heats up... The standard class d, never draw so much idle current, and mostly, the mosfets stay cold during test... I will test this amp for a while.. Thanks Perry
