Amp came In with blown outputs and driver ic’s .
I noticed on the 47mh inductors the voltage jumps all over the place there is no steady voltage it will start at rail voltage then bounce down to 70 volts then back up and continue to cycle like this .
Any ideas on what might cause this ?
With the D1302 removed it fixes the voltage issue .
Next question is the split second I supply remote voltage to the amp the relays engage there is no delay .
As soon as I supply remote voltage the relays engage then the amp itself has the initial startup. Is this normal ? First amp ive ever seen do this usually there is a delay before the relays engage
- General Interest
- Car Audio
- DC Audio 9.0K
