Kicker CXA360.4
Kicker CXA360.4
Thread Tools
Old 16th January 2021, 02:53 AM   #1
cajones65 is offline cajones65  United States
Default Kicker CXA360.4
Having a little trouble with this Kicker. Had one output transistor, D718. I have replaced it and didn't find not other components shorted in the channel.
When I apply power the amp cycles in and out of protect. The outputs are out of the amp now, and it is still doing it.
Scope: HP 54603B/ Hantek DSO5072P, Meter: Fluke 87v, Hakko FX-8888D soldering station, 858D rework station. PS: 30v/10a variable
Old 16th January 2021, 09:57 PM   #2
Pics
Old 16th January 2021, 11:22 PM   #3
I have unsoldered the middle leg of both rectifiers, I get +/- 25 volts on middle legs. The amp is no longer pulsating on and off. The protection LED is still on. Power supply seems to be working fine.
With legs unsoldered amp is only pulling 20ma.
Old 17th January 2021, 06:21 PM   #4
PapaZBill is offline PapaZBill  United States
PapaZBill's Avatar
What channel was the shorted D718 in? Did you replace both the D718 and B688?
You may need to load up the amp with fresh output's. if the amp still flashes in and out of protection, is there an accompanying current draw?
Lifting DP4 and D52-1N4148 (Both will be on the PWM daughter board) will disable output and DC Protection, and allow you to troubleshoot the bad channel. You can also desolder the pin on daughter board that is connected to either cathode of DP4 and D52.
Any sufficiently advanced technology is indistinguishable from magic.
Arthur C. Clarke
Old 17th January 2021, 10:29 PM   #5
The shorted 718 was in channel 2. I only replaced the 718, however I have no outputs in, all 4 channels have been pulled.
Old 17th January 2021, 11:24 PM   #6
Still have the protection in and out
Old 18th January 2021, 02:41 AM   #7
"If the amp still flashes in and out of protection, is there an accompanying current draw?"
Yes just for a quick sec, it may go up to 4-5 amps and drop out. Power supply voltage never drops any. The rail voltage drops out though. Amp will then come back on and then back into protection.
Like I mention before, if I remove middle legs of rectifiers from circuit, the power supply works but, the protection light stays lit
Old 18th January 2021, 09:37 PM   #8
PapaZBill, which pin is it that I need to unsolder? I don't have continuity from either diode to a pin.
Old 19th January 2021, 02:02 AM   #9
PapaZBill's Avatar
I will get back to you tomorrow
Arthur C. Clarke
Old 19th January 2021, 11:47 PM   #10
PapaZBill's Avatar
I was unable to get this info. I will get back tomorrow
Arthur C. Clarke
Kicker CXA360.4Hide this!Advertise here!
Thread Tools
Kicker SoloBaraic 15 cab voluem MadMax Multi-Way 11 2nd June 2003 10:55 AM
For Sale: 2 Kicker Comp Vr 15 subs WhiteBoyChriss Swap Meet 1 6th November 2002 12:12 AM
Kicker VR comp 15 vs. Adire Tempest WhiteBoyChriss Multi-Way 4 4th November 2002 07:29 PM
2 15" kicker solobarics om ebay round s15d nosrunsinthebld Multi-Way 0 25th June 2002 01:51 AM
2 15" kicker solobarics for sale s15d round nosrunsinthebld Swap Meet 0 25th June 2002 01:50 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
