Kicker ZX1500.1 protects when driven hard
Thread Tools
Old 28th January 2021, 12:16 PM   #41
PapaZBill is offline PapaZBill  United States
PapaZBill's Avatar
Are they both ZX1500?
Any sufficiently advanced technology is indistinguishable from magic.
Arthur C. Clarke
Old 28th January 2021, 05:55 PM   #42
peeby is offline peeby
Yes, ZX1500.1 both.
I see from your other posts that the small TL594 driven power supply with the 2 fets should charge C11 and C12 to 17 volts. I am only getting about 8v And all components check ok. The square wave drive from the 594 amplitude in only 5v.
And then the other power supply (TIP 41c and TIP42c) supposed to be at 12V is at almost 16v.
Old 28th January 2021, 08:48 PM   #43
Actually amp seems to be running fine at those voltages. Fully operational on ZX1550.1 #2.
Still working on ZX155.1 #1.
Old 29th January 2021, 09:53 PM   #44
PapaZBill's Avatar
Be aware that this circuit on the secondary side of T1 is isolated and is not referenced to Chassis or Signal GND. Did you measure the voltages on C11 & C12 across the capacitors? The ZX15001 small supply should read ~18 volts DC.
It's odd they would both be 8 volts, Measure the voltages around U1-TL594. You can use the Power or Signal Grounds. Post your results.
Arthur C. Clarke
  Reply to this post
Kicker ZX1500.1 protects when driven hardHide this!Advertise here!
Thread Tools
Kicker KX600.4 protects and led alternately flashing nonprof Car Audio 14 1st June 2016 05:20 AM
Kicker ZX1500.1 without gate drive. Randy62 Car Audio 7 29th May 2013 06:47 PM
kicker zx1500 mosfet question ksweet420 Car Audio 9 11th March 2013 10:12 PM
kicker zx1500.1 output inductor? shane300zx Car Audio 9 2nd August 2011 09:58 AM
Kicker zx1500.1 not working Andrew123654 Car Audio 12 19th October 2010 01:04 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
