Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#31 |
those ZR "grille" amps love to eat outputs. I've noticed that.
#32 |
OK - low voltage is fine and have voltage on the class d card but now no output from the card. I killed it somehow.
-drv is 3.6v and +drv is 5.2v dc measured on scope. Dc no oscillation. Any suggestions on which IC's to replace? All diodes, caps and resistors are checking ok. |
#33 |
Look at the U202-LM361 with an Oscope Pins 3,4,9 & 11 and measure DC volts around U200,201,202 & 203. Post voltages and screenshots.
It's possible the problem is the Drive circuit underneath the card. Q100,102,OPT100,101 & U100,101. To check this circuit you may want to modify the Class D card, so that you can stand card upright to get to the drive circuit underneath. I have done this by bending the pins by 90 degrees on one side and extending the pins on the other with ribbon cable.
Any sufficiently advanced technology is indistinguishable from magic. Arthur C. Clarke |
#34 |
PapaZBill- what is the value of D7? Placing a parts order. Thanks
#35 | |
Best Regards, Russell ![]() Wherever you go, there you are. --Buckaroo Banzai |
#36 |
D7-1N4148
#37 |
Russell, you may know this, but Kamen Vasilev designed this amp. For the most part it's not a bad amp to work on but the drive circuit underneath the daughter board does add a challenge.
#38 |
Re#33:
You can make male/female ribbon cable jumpers for headers with full length pins. This doesn't work for driver boards that are soldered into the boards due to the short pin length. The ones for JL amps are great time savers.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version. |
#39 |
PapaZBill - I actually have 2 of these amps. My other one the +/-12V regulator is putiing out 15V. Why would that be? Measuring +/-15 at the zeners. And will that cause problems with the IC's?
#40 |
In later versions the +/- voltage was beefed up.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Kicker KX600.4 protects and led alternately flashing | nonprof | Car Audio | 14 | 1st June 2016 05:20 AM |
Kicker ZX1500.1 without gate drive. | Randy62 | Car Audio | 7 | 29th May 2013 06:47 PM |
kicker zx1500 mosfet question | ksweet420 | Car Audio | 9 | 11th March 2013 10:12 PM |
kicker zx1500.1 output inductor? | shane300zx | Car Audio | 9 | 2nd August 2011 09:58 AM |
Kicker zx1500.1 not working | Andrew123654 | Car Audio | 12 | 19th October 2010 01:04 PM |
New To Site? | Need Help? |
