Download the following SM and look at page 7. Are they the same?
HERTZ EP1D Service Manual download, schematics, eeprom, repair info for electronics experts
If you power up through a limiter, will it go into protect?
The following seem o be in conflict. Please clarify.
Rail voltage is possible only if I have rectifiers on board. As I install rectifiers it going into protect.
I mean rail voltage comes from main rectifiers right.
Without them in board no rail voltagebis generated.
If I remove the main rectifiers amp is coming on. But with main rectifiers amp goes straight to protect and tries to start and protect. It keeps cycling. This is with current limiter.
With current limiter also it goes into on and protection cycle.
- General Interest
- Car Audio
- Kyle audio Trax1-1800D
