PPI pro mos 450 pulses when powering on
Thread Tools
Old 24th November 2020, 11:54 PM   #1
GEM 592 is offline GEM 592  United States
Default PPI pro mos 450 pulses when powering on
Hello,
I have a PPI pro mos 450 that a friend bought used then sent to me to check.
I connected the amp, and checked all four channels - seemed fine. About 30 seconds after playing, the sound cut out, and the power led started pulsing.
I can connect ground and +12V without any apparent issues, but when I connect the remote to +12V the amp just pulses with the power led flashing.
I can't see any obvious signs of damage, short circuits in power supply devices, etc.
Any ideas are appreciated, thank you.
DMM (Fluke 115), good power supply (100 A, 12 to 16.5 V), soldering irons and skills.
Old 24th November 2020, 11:57 PM   #2
Perry Babin is offline Perry Babin  United States
Did you check the output transistors to see if any were shorted?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 24th November 2020, 11:58 PM   #3
Will do right now.
Old 25th November 2020, 12:10 AM   #4
There is a bank of 5 2N6487 with base to emitter impedance reading very low, 0.2 or 0.5 Ohms. Not seeing this in the other banks of these, typically minimum of about 47 Ohms elsewhere.
Old 25th November 2020, 12:12 AM   #5
Find the lowest one and remove it from the circuit. After that, do the rest read like the others?
Old 25th November 2020, 12:34 AM   #6
I wound up having to remove 2 of the 5, the remaining 3 now read base to emitter resistance 47 Ohms, which is similar to corresponding measurements on the other side of the amp.
Out of circuit, base to emitter is reading 0.5 Ohms on both removed devices.
Old 25th November 2020, 12:37 AM   #7
Were you testing with the bottom cover removed?
Old 25th November 2020, 12:39 AM   #8
No, I know that acts like a clamp.
But, interesting story, when he received the amp, one screw was missing. That was replaced first, but maybe it caused the problem previously.
Old 25th November 2020, 12:42 AM   #9
How much matching would you recommend for the replacements? Obviously, at least that bank of 5 should be date-code matched, should I replace the complimentary 5 2N6490 on that channel too at least?
Old 25th November 2020, 12:42 AM   #10
You'll have to replace all 5 transistors in that group. I'd suggest the other 5 in that channel as well. Each group of 5 needs to have matched date codes.
Carefully check the emitter resistors as well.
PPI pro mos 450 pulses when powering onHide this!Advertise here!
Thread Tools
Easy-MOS is a simplistic, efficient and evolutive all-MOS amplifier for beginners Elvee Solid State 131 16th June 2020 10:27 AM
Ppi mos-450 Triviumfan4 Car Audio 11 21st September 2017 02:07 PM
How to measure rectifier recovery current pulses merlin el mago Power Supplies 8 12th July 2012 02:49 PM
Counting digital pulses and resetting akis Digital Line Level 8 2nd May 2012 11:24 AM
n-mos half-bridge class D amp, how to drive high side n-mos? zilog Class D 1 30th October 2005 10:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
