Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#31 |
I wonder if putting foam strip on the tabs would do more harm than good.
The thermal tape is non-adhesive. Perhaps compound under it would help. Thank you for your help.
DMM (Fluke 115), good power supply (100 A, 12 to 16.5 V), soldering irons and skills. |
#32 |
You definitely need compound on the top and bottom of the tape if it's non-adhesive.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version. |
#33 |
OK I straightened a few bent tabs, added heavy compound below tape, added heavy compound on each device, straightened all devices to lay flat (just pushing each with my finger they stick down flat and stay), torqued down back panel very well. Ready to test again.
#34 |
When you test, use a current limiter or a 10 amp fuse. It may save parts if there is still a problem.
#35 |
Like 3 or 4 songs in, sink is warming up little. Never played this long at least, so if it fails again I probably just need to go back and improve the heat sink mating more. I think it is really really good now though.
Thank you very much Perry for your help, knowledge, and patience.
#36 |
I've been rechecking the clamp screws when it warms up.
It seems like it is repaired. Sounds very very good, better than I was expecting honestly. I don't suppose anyone has a solution for the speaker output plug problem. I remember seeing somebody did a custom deal.
#37 |
The spacing is a bit odd.
I know this probably isn't what you want but I'd remove and keep the terminal in case you find a mate for it. Some people solder wires to the board and go out a few inches to a screw-type terminal strip. Something even easier, go out a couple of inches to male/female push-on connectors. These aren't fancy but they do no harm, either.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Easy-MOS is a simplistic, efficient and evolutive all-MOS amplifier for beginners | Elvee | Solid State | 131 | 16th June 2020 10:27 AM |
Ppi mos-450 | Triviumfan4 | Car Audio | 11 | 21st September 2017 02:07 PM |
How to measure rectifier recovery current pulses | merlin el mago | Power Supplies | 8 | 12th July 2012 02:49 PM |
Counting digital pulses and resetting | akis | Digital Line Level | 8 | 2nd May 2012 11:24 AM |
n-mos half-bridge class D amp, how to drive high side n-mos? | zilog | Class D | 1 | 30th October 2005 10:46 PM |
New To Site? | Need Help? |
