Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#11 |
Thank you Perry, you are the best. I will update after the replacements.
DMM (Fluke 115), good power supply (100 A, 12 to 16.5 V), soldering irons and skills. |
#12 |
Hello,
I carefully checked emitter resistors, and replaced all 10 outputs in the channel in which the bad outputs were found. I reassembled the amp for a bench test. The same symptom is occurring - when remoting the amp on, the power led just pulses (and my lamp dims like current is being drawn.)
#13 |
Now I've found at least one bad output in a group on the other side of the amp.
I don't remember seeing these last time, I guess I just missed them. Is it possible to blow outputs without even connecting speakers? I suppose I should just lift those out a see if it powers up.
#14 |
OK I lifted the lowest base-emitter resistance device, rest of group read OK.
Did power-up test and it appears to power up normally now.
#15 |
Was it another 6487/6490?
It's possible to have virtually any component fail without a load. If it's another output transistor, they could be failing due to age.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version. |
#16 |
Yes, and just one in the corresponding channel on the other side of the amp.
This one is a 90, before it was and 87. The channel I replace still reads OK after letting the amp stay on idle for a few minutes.
#17 |
The outputs can overheat at idle if not clamped down. There should be no bias current (and no heating) but the biasing can drift.
#18 |
Thank you. I have been clamping it. Almost ready to retry.
#19 |
You should make absolutely sure that the transistors lay perfectly flat on the heatsink. If not perfectly flat, the cover may not push them flat.The edge of the transistor can dig into the insulator and leave the transistor off of the sink (attached).
#20 |
OK all four functioning. Testing. Sounds right so far.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Easy-MOS is a simplistic, efficient and evolutive all-MOS amplifier for beginners | Elvee | Solid State | 131 | 16th June 2020 10:27 AM |
Ppi mos-450 | Triviumfan4 | Car Audio | 11 | 21st September 2017 02:07 PM |
How to measure rectifier recovery current pulses | merlin el mago | Power Supplies | 8 | 12th July 2012 02:49 PM |
Counting digital pulses and resetting | akis | Digital Line Level | 8 | 2nd May 2012 11:24 AM |
n-mos half-bridge class D amp, how to drive high side n-mos? | zilog | Class D | 1 | 30th October 2005 10:46 PM |
New To Site? | Need Help? |
