Xtant 404M
Xtant 404M
Thread Tools
Old 24th November 2020, 05:13 AM   #1
Mitch04 is offline Mitch04  United States
Xtant 404M
Default Xtant 404M
Hello All,
I've been trying to ask for help as little as possible, I tend to learn much more when I have to figure something out, but this one is something I don't understand.
When I got the amp, the power FETs were shorted out, so I replaced them.
This amplifier will show a normal signal on the power FETs when the rectifiers are out, but when they were in I get this... where it's like two or 3 waves over top of each other. When the power FETs were out, I had the same signal. I thought maybe it was the driver, so I replaced that, but clearly it didn't help.
I thought maybe someone would have seen it before or have an idea what causes it. I'm all ears!
Siglent Technologies SDS1202X-E Oscilloscope, OTC 750 Multimeter, Kaiweets 10A 30V DC Power Supply, Weller WES51 Soldering Iron, Hakko FR301 Desoldering Gun,
Old 24th November 2020, 05:14 AM   #2
Xtant 404M
I apologize again for the rotated photos, I do not understand why they rotate once I upload them.
Old 24th November 2020, 07:25 AM   #3
Perry Babin is offline Perry Babin  United States
The scope isn't triggering properly. Take it off of auto, set the timebase to 10us, the vertical amplifier to 5v/div and the coupling to DC. Adjust the trigger level until it displays one single line of pulses on the base.
Change the vertical amp to 10v and then probe the drains. Readjust the trigger level is needed.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 24th November 2020, 01:41 PM   #4
Xtant 404M
Ok, I did that and here is what I ended up with...
Old 24th November 2020, 03:49 PM   #5
Try reducing the voltage on your 12v power supply. Does that give you more of what you expected?
Old 24th November 2020, 06:29 PM   #6
Xtant 404M
This is just above 9 volts, iirc.
So is this normal for this amplifier? When I have it at around 13v, it'll show +-25v on the rails. The rectifier wave looks so much different than the other amps I've worked on.
The amp powers up without protection coming on, but unfortunately I haven't set up a test bench in our tiny temporary apartment. I had planned on waiting until I had the amps all ready, then taking them to my shop and testing them all in a vehicle.
Old 24th November 2020, 08:43 PM   #7
The power supply is regulated. When the pulse width decreases (when the rails reach their target voltage), the waveforms won't look perfectly square. Decreasing the 12v supply voltage forces the pulse width to increase to try to maintain the target voltage.
Old 24th November 2020, 09:04 PM   #8
Xtant 404M
Awesome, thanks for the explanation. Makes sense now!
So when I had the rectifiers out, it wasn't getting any rail voltage and was commanding full pulse width to increase power, which makes for a nice wave.....correct?
Is there any "giveaways" when looking at an amplifier board as to whether or not it is regulated?
Old 24th November 2020, 09:06 PM   #9
Xtant 404M
(Side note instead of sending another email) Perry, the amplifier I had asked you about with the single side of rail caps blown ended up having a broken transformer winding. Thanks for the help there as well!
Old 24th November 2020, 09:26 PM   #10
Yes. It was doing all it could to get to the target rail voltage but could not, even with full duty cycle.
Many (not all) of the amps with regulation have inductors in the secondary circuit.
The definition of 'regulated' varies. Some regulation never engages except for over-voltage situations that would cause rail caps to fail. Some regulation is minimal and may be used to make it easier to keep the bias stable at low power. Some regulation is extreme. This is seen in amps that precisely double power when the load is halved (ie, 4 ohms to 2 ohms).
  Reply to this post
Xtant 404MHide this!Advertise here!
Thread Tools
Xtant 404M Jason Smith 616 Car Audio 1 3rd April 2017 08:31 AM
Xtant 404M singing NickParr666 Car Audio 1 2nd June 2016 09:55 PM
Help::Xtant 404M Recifiers/Fets? ItsAGizmoLife Car Audio 0 11th November 2012 04:09 PM
help troubleshooting XTANT 603x problem! pape Car Audio 12 18th September 2004 11:40 AM
Xtant 604X / 2 ohm sub jimeez Car Audio 1 10th January 2004 06:35 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
