Quantum Audio QEQ6 pre-amp with no output
Thread Tools
Old 24th November 2020, 08:17 PM   #11
mild2wild is offline mild2wild  Trinidad and Tobago
Tested the four diodes on ohms and got 0 ohms in both directions for all.
I tapped the base of Q1 and Q2 and got some readings on the scope but only on the 2 outer windings of the secondary ones. There were no reactions visible on the 2 inner windings where they enter the board. There was barely any visible response to a single tap of the 100 ohm resistor connected to ground, so I tapped in quick succession to achieve these screenshots. These were with the diodes resoldered back in.
Mestek DM91A/Sonometer VC9808/OWON VDS1101I/Quimat DSO Shell/N.A. DVP-712LJ 13.8v/5-7A
Old 24th November 2020, 08:20 PM   #12
Trying to post this pic straight, my pics keep getting rotated...
Old 24th November 2020, 08:40 PM   #13
Perry Babin is offline Perry Babin  United States
Make sure that the 2 small windings are not broken.
0 ohms is a direct short and would indicate that all 4 diodes are shorted.
The solder connections on many of the components between the transformer and the closest end of the board look dodgy. Desolder them completely, stand the legs up straight and resolder them.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 25th November 2020, 05:37 AM   #14
I removed the transformer and checked all the windings. No breaks, continuity along each lead, and no evident cross-conducting.
I retested the diodes with the meter on auto-ranging. They read 1.6Mohms in one direction, and around 60Mohms in the other.
I removed and resoldered all of the components in the power supply area. I removed and tested the capacitors in the area and they are within tolerance.
Can't get this power supply to start, and don't know what to do next. The only action I see with this is when I touch the board /transformer with my fingers, then I see voltage, as much as +7v on the secondary side and the opamps VCC pins...
Old 25th November 2020, 06:12 AM   #15
You may be able to tell something about the condition of the supply by injecting a signal from another power supply. I don't know how badly you want to repair this piece.
Old 25th November 2020, 11:49 AM   #16
Tell me what to do. It's a friend's own and he will really like to get it working.
Old 25th November 2020, 03:13 PM   #17
When you checked Q1 and Q2, did you check for open junctions and leakage, in addition to checking for shorted junctions?
Old 25th November 2020, 04:16 PM   #18
No I didn't. I just did a normal transistor test using diode function on the meter.
Old 25th November 2020, 10:56 PM   #19
Ok, so Q1 and Q2 were defective. I don't have KSP06 so I used MPSA06 as the specs were identical. The power supply powers up but not sure if the output voltage is correct. The supply voltage to the opamps is +29.5v when measured across the + and - legs of the ICs. I am just accustomed to 5v and 15v supplies so this may be correct and normal but I just need to be told that nothing is amiss. I haven't tested for sound or anything either...
Old 25th November 2020, 11:03 PM   #20
Across 4 and 8 at 30v is ±15v.
  Reply to this post
Quantum Audio QEQ6 pre-amp with no outputHide this!Advertise here!
Thread Tools
Cables: Quad pre- to Quantum power- p1lyp Solid State 1 27th June 2014 05:41 PM
Quantum Audio QCA4000D S Merlington Car Audio 51 27th August 2013 01:14 PM
quantum audio qsa 1500d op amps missing voltage ivkata Car Audio 2 18th February 2013 07:27 AM
FS: ESX Quantum Q120.4 Steve Mantz (Zed Audio) Mobile Amplifer (4x120 @ 4 ohms/12V) omarmipi Swap Meet 1 2nd December 2010 11:31 PM
Quantum 102 Pre-Amplifier rocky99 Solid State 0 14th January 2008 08:30 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
