Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
I want to test a audio drive board outside the amp, with a self build power supply. Is it enough to provide +-5v, +15v and +12v to engage the irs 21844s?
2Ch. DSO, Multimeter, Hot Air Station, Soldering Irons, 12V Server Supply, L-C-R Tester, Component tester |
#2 |
What tests are you going to try to perform?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version. |
#3 |
Oly output signal and oscillation
#4 |
You'll have to supply the high-side B+.
Are you referring to the oscillation that's produced by the drive signal (that you'll have to supply) or do you expect it to oscillate at near 100kHz like it does when the amp is functioning? Are you going to load the outputs to simulate the FETs being in the circuit? Are you going to try to get it to vary the pulse width?
#5 |
No, only test oscillation. Outside of the amp without any other components.
#6 |
It's like a testbed only for that cards.
#7 |
High-side B+ and a drive signal may be all you need. Try it.
#8 |
I did it! I made a test bench on a bread board, with a linear (toroidal) power supply generating +/- 30v rails (of which only the negative rail is used). Through a separate winding it is possible to generate the auxiliary voltages of +/- 5v (the voltage of 15v is not needed, because it is used only for the lm293 which carries out the protections) and through a second separate winding with reference to the negative rail, I obtained about 20 volts which I stabilized at 12volt with a regulated lm7812 to power the low side of the ICs. To power the high side, simply connect VS with the negative rail and magically you will also have modulation on the high side. I also thought about building a circuit (using professional services) made specifically to test these boards, but I find it too stressful, because every time I have to test the driver cards externally, I just have to prepare my bread board for the need ( it only takes 10 minutes).
Personally I think that all these tests can also be done with the driver board mounted on the amplifier (without the mosfets) but hey, you're right, because the amplifier runs very high voltages which in case of problems can damage the board. Also on the amplifier, generating the power for the high side, could trigger unwanted protections. Most importantly, if you take apart a driver card to repair it, right after you do, you'll want to try it out, so better try it out before you mount it on the amplifier.
Two things save us in life: love and laugh. If you have one, that's fine. If you have both, you are invincible. ![]() |
#9 |
Hello, thank you for the Information. I have a laboratory power supply, which makes up to 30VDC. So i need only the Voltage regulators. I like to test the boards outside the amp, because i dont like to test with 200V and more. I think it makes it more easy. Ok, i will start to build now.. I will report when iam finished.
#10 |
Finished... Now I will test a drive board
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
How to use a dual opamp separately as two single opamp | Sunsun22 | Parts | 14 | 21st May 2016 04:08 PM |
DWM 3640 Driver Board | bl4ckw1d0w | Car Audio | 26 | 18th May 2016 10:02 AM |
bypassing DIN-9pin on a Sanyo DWM-3500 noob help | camcam089 | Everything Else | 1 | 12th January 2015 08:38 AM |
DWM 3640 CL2 CL3 | bl4ckw1d0w | Car Audio | 2 | 3rd June 2014 12:09 AM |
Double woofer design - measure together or separately? | btntx | Multi-Way | 3 | 7th November 2013 12:51 AM |
New To Site? | Need Help? |
