Test class d dwm drive board separately
Thread Tools
Old 21st November 2020, 08:13 PM   #21
Perry Babin is offline Perry Babin  United States
A current limiter should be used. Something like an 1157 lamp would be better than nothing.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 21st November 2020, 11:51 PM   #22
Achim1409 is offline Achim1409  Germany
Maybe Mario could say something. I use a toroidal transformer with 26v 0v 26v. I used a positive rectifier and a negative rectifier.. So I habe +30vdc,0v,-30vdc. I used regulators to produce +5vdc, - 5dc and a lm 7812 to produce +12vdc. All have a common ground.. I used +12 and common ground for the irs... And I think that's the problem.
2Ch. DSO, Multimeter, Hot Air Station, Soldering Irons,
12V Server Supply, L-C-R Tester, Component tester
Old 21st November 2020, 11:54 PM   #23
Terminals 3 and 5 of the IC are typically at negative rail. The +12v reg has it's ground on the negative rail. The 5v are referenced to ground.
Post the DC voltage on all terminals of the 21844 IC.
Old 22nd November 2020, 03:30 PM   #24
I modified my Power supply.I have a second winding, which is now used for the 12V.
The Negative is tied togehter with the negative rail.
The +-5V use a common center with negative and Positive rail..
Problem is now, that if i measure the osciloscope the 12V + and Negative rail, i have my clean 12V.
If i measure between +12V and common ground, the voltage isnt clean. Its flickering .
Is there a possibility to connect negative rail and common ground? Maybe with a ceramic cap?
Old 22nd November 2020, 03:45 PM   #25
Is the negative rail stable if you use the common ground for the scope's reference?
Old 22nd November 2020, 03:49 PM   #26
No, it looks like the rectifier is not working clean
Old 22nd November 2020, 03:51 PM   #27
This is the negative rail
Old 22nd November 2020, 04:13 PM   #28
It appears to have insufficient capacitance.
Old 22nd November 2020, 05:45 PM   #29
Added some railcaps. Voltage is OK now.
I measured pin 1 with 50hz sine injected. No irs mounted..
what can cause this picture?
Old 22nd November 2020, 05:51 PM   #30
MarioRestucci is offline MarioRestucci  Italy
MarioRestucci's Avatar
This is my power supply. You can see how I check the cards outside the amplifier. Pay close attention to where you put and where you don't put the negative rail.
Sorry, in picture the winding for +/-5v have an unconnected pin, is obviously connected to GND.
Two things save us in life: love and laugh. If you have one, that's fine. If you have both, you are invincible.
Test class d dwm drive board separatelyHide this!Advertise here!
Thread Tools
How to use a dual opamp separately as two single opamp Sunsun22 Parts 14 21st May 2016 04:08 PM
DWM 3640 Driver Board bl4ckw1d0w Car Audio 26 18th May 2016 10:02 AM
bypassing DIN-9pin on a Sanyo DWM-3500 noob help camcam089 Everything Else 1 12th January 2015 08:38 AM
DWM 3640 CL2 CL3 bl4ckw1d0w Car Audio 2 3rd June 2014 12:09 AM
Double woofer design - measure together or separately? btntx Multi-Way 3 7th November 2013 12:51 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
