Pioneer KEX-M900 troubleshooting
Thread Tools
Old 24th November 2020, 10:22 AM   #21
Perry Babin is offline Perry Babin  United States
Pin 5 shouldn't drag the signal down. The IC or one of the capacitors connected to pin 5 may be defective.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 24th November 2020, 10:31 AM   #22
vincegironda is offline vincegironda
Thanks Perry
Sorry I'm a little confused, by IC do you mean IC757?
There are 4 capacitors in the 763 circuit should I go ahead and replace all 4?
Old 24th November 2020, 10:41 AM   #23
I just pulled the caps and tested them, all appear good and within tolerance
Old 24th November 2020, 10:46 AM   #24
I was referring to the op-amp IC763 (the one that caused the signal from IC764 to be dragged down).
Before replacing anything, measure the resistance from IC763, pin 5 to ground and compare that resistance to the readings on pin 5 of the other op-amps.
Old 24th November 2020, 11:02 AM   #25
Pin 5 to ground resistance
764 42.8 k Ohm
763 000.7 Ohm
762 43.1 k Ohm
761 1.93 m Ohm
Old 24th November 2020, 11:08 AM   #26
If it's easily accessible, remove it and re-check.
Old 24th November 2020, 11:24 AM   #27
With 763 removed
764 42.8 k Ohm
763 000.2 ohm
762 43.1 k Ohm
761 1.8 m Ohm
Old 24th November 2020, 11:25 AM   #28
It would appear that the fault is a shorted capacitor.
Old 24th November 2020, 11:39 AM   #29
I just checked all the capacitors on the dsp board and none are shorted
Should I pull them off the board and re test?
Old 24th November 2020, 11:42 AM   #30
Something connected to pin 5 has to be shorted. C793 is the most likely suspect.
Pioneer KEX-M900 troubleshootingHide this!Advertise here!
Thread Tools
Pioneer KEX-900 8-pin DIN AUX to 3,5mm audio jack. Mep Car Audio 1 16th September 2020 01:01 PM
Bridging an H&H m900 (400w/ch@4ohm) to run two 16ohm H&H Bass Bins in parallel? Ovation Solid State 8 20th July 2016 09:02 AM
Pioneer KEX-900 blowing fuse dhamia Car Audio 3 14th October 2010 09:25 AM
Pioneer KEX-900 security code dhamia Car Audio 6 22nd September 2010 09:27 AM
Manual and schematic of Pioneer KEX 23 SDK tsteuerwald Car Audio 0 29th March 2007 07:46 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
