A/D/S power plate 80 and 100
Thread Tools
Old 26th November 2020, 05:41 AM   #71
Perry Babin is offline Perry Babin  United States
Ordering from mouser or digikey will be easier.
I don't think the 4001 will hold up. It's only a 50v diodes but you could try it. One end on the AC and the other end (striped end) on the positive. Power up for just a few seconds to see if you get positive voltage on the rail cap.
To answer your other question, you need a 100v or greater rectifier with a reverse recovery time (Trr) of about 35ns. If the threaded locations near the power supply transistors are unused, I'd recommend the MUR1620CT and the MUR1620CTR. You'll need other bits and pieces as well (to be covered later).
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 26th November 2020, 05:45 AM   #72
Rabbit 16v is offline Rabbit 16v
Ok cool, thanks again! I really appreciate the help. I will do some digging and order something up. Rather not accidentally cook something I couldnt even implement anyway.
I will search for something proper that can handle it. Thanks for the part numbers! I want to try and find something with the same package style so it all fits correctly. Its screwed down onto a heat sink, so I think that might be important.
n00b, Fluke 87, Fluke 97 scopemeter (auto),Fluke TS1000, Fluke 376 FC, Lectrotech to-55
PS-106, 12v regulated power supply with crappy ammeter
Old 26th November 2020, 05:46 AM   #73
Why not try it?
Old 26th November 2020, 10:09 AM   #74
Limited parts (think I only have about 6 of these low wattage ones), and effort. I would prefer to get something that I might use as a final solution. Thats whats neat about all this is parts are cheap.
Old 26th November 2020, 01:09 PM   #75
Is the positive rail cap shorted?
Testing with something that may or may not work may reduce the number of orders that need to be placed to get the job done.
What's the thread size of the threaded insert in the heatsink? 3mm? 4-40?
Old 26th November 2020, 06:19 PM   #76
I believe I tested both caps by pulling them and testing resistance and they seemed ok. I can test again though.
You mean just assemble the 1n4001s in the same configuration as what is shown in the schematic?
The heat sink is a cast part of the amp body. The hole in the rectifier is about 4mm I think.
Old 26th November 2020, 09:01 PM   #77
On the plate where the power supply transistors are mounted, there are 2 locations that are not used. Those locations have threaded holes. Do you see what I'm referring to?
Old 26th November 2020, 09:09 PM   #78
Yes. 3mm is the size.
Old 26th November 2020, 09:14 PM   #79
The following image shows the rectifiers that you will mount in those locations.
Do you have insulators, shoulder washers, 3mm screws to mount them?
One transformer winding will go to terminal 1 of each rectifier. The other transformer winding will go to terminal 3 of each one.
Don't order yet.
For now, I simply want you to install one of the 1N4001 rectifiers to see if it will build positive rail voltage.
Old 26th November 2020, 09:36 PM   #80
The ones in the image I do not have. I have the B289s and the 1n4001s. Obviously the package shape of the 1m4001s wont allow for any sort of screwing down for heat dissipation. I can steal the screws with washers and insulators from the other amp as its very much the same construction, just more bits.
I can put the 1n4001 diodes in the configuration of the image though if thats what you mean.
A/D/S power plate 80 and 100Hide this!Advertise here!
Thread Tools
Plate to plate feedback and gain Miniwatt Tubes / Valves 5 22nd May 2019 11:40 AM
Plate-to-plate negative feedback: pro and cons ygg-it Tubes / Valves 2 9th February 2017 07:42 PM
Plate current and red plate problem dscottguitars Instruments and Amps 22 22nd November 2012 06:06 AM
FS pair of ADS power plate 100 amps woody Swap Meet 2 6th June 2011 04:07 AM
Subwoofer Plate Amplifier Base Plate supplier? jwells777 Parts 1 11th May 2003 08:40 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
