Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#241 |
Check Q1 for leakage.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version. |
#242 |
Ok, I will do some reading on how to perform this test. Not familiar with this. Thanks again!
n00b, Fluke 87, Fluke 97 scopemeter (auto),Fluke TS1000, Fluke 376 FC, Lectrotech to-55 PS-106, 12v regulated power supply with crappy ammeter |
#243 |
Ok, I guess the terminology just threw me off. I presume you just meant to ensure no voltage leakage when testing in diode mode on the bench. There is no voltage leakage. Everything that should not have continuity doesnt, and everything that should, has a solid reading.
#244 |
You can't detect low level leakage on diode-check. You have to use resistance.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Plate to plate feedback and gain | Miniwatt | Tubes / Valves | 5 | 22nd May 2019 11:40 AM |
Plate-to-plate negative feedback: pro and cons | ygg-it | Tubes / Valves | 2 | 9th February 2017 07:42 PM |
Plate current and red plate problem | dscottguitars | Instruments and Amps | 22 | 22nd November 2012 06:06 AM |
FS pair of ADS power plate 100 amps | woody | Swap Meet | 2 | 6th June 2011 04:07 AM |
Subwoofer Plate Amplifier Base Plate supplier? | jwells777 | Parts | 1 | 11th May 2003 08:40 AM |
New To Site? | Need Help? |
