MTX JH1200 repair
MTX JH1200 repair
Thread Tools
Old 27th November 2020, 07:34 PM   #41
Perry Babin is offline Perry Babin  United States
Was the only problem with the original circuit that the components were heating up?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 27th November 2020, 09:09 PM   #42
tobyret2 is offline tobyret2
I have not seen it in working order this ampliefer. I assembled a circuit with transistors and zener diodes, it worked, but the transistors were very hot. Now everything is fine with +-15v. These transistors are heating on the driver board .. I dropped them out and all that are connected to them, everything is ringing well with a multimeter. by the way, the fan speed in this amplifier depends on the input signal level)
Old 29th November 2020, 01:39 PM   #43
Perry, you have a schematic of this driver? Why, on the basis of the q109 transistor, I have a quadratic impulse, but on the basis of the q128 it is not? Oscilloscope ground to amplifier ground
Old 29th November 2020, 02:47 PM   #44
I don't have a diagram for that amp.
Those two transistors may be the same as Q18 and Q19 in the following Sony amp:
http://www.bcae1.com/temp/sony%20-%2...ifier%20SM.pdf
Old 3rd December 2020, 03:45 PM   #45
I fixed it. After doing + -15v, I installed tl072 incorrectly. Now the sound is there, the only thing I don't like is the hot output chokes and hot transistors on the driver board. But there is sound, nothing has been burning for an hour
Old 3rd December 2020, 03:55 PM   #46
There are a LOT of amps that use this basic circuit design and virtually all of them have problems with drivers overheating. You can see the heat stress in the board in your photo. That's also common in various layouts. In some instances, it's so bad that it causes the board to become conductive.
  Reply to this post
MTX JH1200 repairHide this!Advertise here!
Thread Tools
MTX JH1200 RiLoWa Car Audio 72 19th November 2020 01:31 PM
orion hcca250r, kicker zr 1000, mmats d800.2, mtx 6500d, mtx 942, rockford punch 45, ernie cosillos Swap Meet 3 12th February 2011 12:14 PM
MTX JH1200 burned resistor R140-R141 & R142 joselorenzo Car Audio 0 27th December 2009 08:18 AM
Help me fix MTX 152 and MTX 500D hakentt Car Audio 94 8th December 2008 07:26 PM
MTX 6500D repair bil Car Audio 3 29th May 2006 07:19 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
