MTX JH1200 repair
MTX JH1200 repair
Thread Tools
Old 23rd November 2020, 09:47 AM   #21
Perry Babin is offline Perry Babin  United States
There could be multiple thermistors.
Are the regulators fed off of the emitters of the two transistors near the diodes you replaced?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 23rd November 2020, 10:03 AM   #22
tobyret2 is offline tobyret2
no. they are powered from the transistor emitters on the driver board. I think all the problems are in the power supply + -15v. On tip29 bases tip30 comes 70v, so it should be?
Old 23rd November 2020, 10:05 AM   #23
next to the diodes in the photo tip29c tip30c from the emitters of which there is a voltage on the lm317 lm337
Old 23rd November 2020, 10:18 AM   #24
Install a 25v Zener in place of the diodes you replaced. That will make the TIP transistors run hotter and will make the regulators run cooler. It will also help with their reliability since they're only rated for 40v.
Old 23rd November 2020, 10:32 AM   #25
15v zener diode will not be enough? Should there be an NPN or PNP transistor in the lm317 power circuit?
Old 23rd November 2020, 10:43 AM   #26
The two preregulators are NPN and PNP.
You could install two Zeners in series if you don't have anything near 25v. The regulators need a bit of headroom over the regulated voltage to work properly.
Old 23rd November 2020, 12:34 PM   #27
Nothing works. The transistor heats up strongly if the load is lm ***. Am I doing the right thing, before the lm337 is a PnP transistor? to its base a zener diode 22v which makes -22v. Total obtained on the basis of PnP transistor -22v collector -80v emitter -22v
Old 23rd November 2020, 05:24 PM   #28
What is the DC voltage on all 3 terminals of each regulator?
Old 24th November 2020, 09:43 AM   #29
lm337 1- -13.5 2- -22 3- -15
lm317 1 13.5 2- 15 3- 22
Old 24th November 2020, 10:27 AM   #30
That establishes the fact that the transistors are pre-regulators. I don't know if they are the voltage source for any other components.
If not, use a zener value that causes the heat to be distributed evenly between the regulators and the pre-regulator transistors. The voltage between the input and output of the individual regulators can't be more than 40v. Anything below that is safe.
MTX JH1200 repairHide this!Advertise here!
Thread Tools
MTX JH1200 RiLoWa Car Audio 72 19th November 2020 01:31 PM
orion hcca250r, kicker zr 1000, mmats d800.2, mtx 6500d, mtx 942, rockford punch 45, ernie cosillos Swap Meet 3 12th February 2011 12:14 PM
MTX JH1200 burned resistor R140-R141 & R142 joselorenzo Car Audio 0 27th December 2009 08:18 AM
Help me fix MTX 152 and MTX 500D hakentt Car Audio 94 8th December 2008 07:26 PM
MTX 6500D repair bil Car Audio 3 29th May 2006 07:19 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
