Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
Does anyone have practical experience with a replacement for the mosfet huf75343p3?
Digikey recommend the STP80NF55-08AG. Gate resistors are 18 Ohm. These mosfets are in a Steg Masterstroke 3000 power supply.
TOE8851 - 32V 10A / QJ1503 - 15V 3A / Dell AA24150L - 12V 175A / Yokogawa DL1640 / Fluke 87V / Fluke 325 / Sony CDX-GT650 / Weller WSD 81 / Hot Air Station / 4x Dummy Load 1000W 4ohm |
#2 |
I've used IRF3205 and 33-47ohm gate resistor whit no problem.
I've rebuilded 15+ masterstroke msk3000 in this way and never had problem.
Two things save us in life: love and laugh. If you have one, that's fine. If you have both, you are invincible. ![]() |
#3 |
What about the IRF3205? I don't know this amp but it works as a good sub in most amps.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version. |
#4 |
Thanks! I will order the IRF3205 and Gate resistors.
#5 |
IRF3205 with 33 ohm gate resistor works fine. Also changed the driver BD139/140.
Thanks a lot.
#6 |
I'm searching this diode. The left one is shorted. Driver board output section.
I see only one blue stripe on the cathode. Any idea? Maybe put all parts back and measure the voltage on the good one?
#7 |
It's a 6.8V zener diode.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
low noise replacement for BC547, BC557, BD135, BD136 | k.junold | Everything Else | 16 | 5th August 2012 08:28 PM |
help with replacement tweeter replacement - KLH twenty three | indianajo | Multi-Way | 2 | 15th February 2010 01:54 AM |
Help !!! I need to locate a replacement driver! | arexk | Multi-Way | 3 | 23rd January 2006 03:49 PM |
replacement for ECC88 ? | Emil | Tubes / Valves | 6 | 23rd February 2002 03:43 PM |
MOSFET replacement | carlmart | Solid State | 0 | 9th October 2001 11:13 PM |
New To Site? | Need Help? |
