Logic Gate IC
Hi . Almost every logic ic can be checked , need to understand how it should work , this is specified in datasheet , named truth table . Just supply 5v to ic and measure voltage at outputs ,and change input from zero to 5v , depending on logic. You wanna check 14011 ?
It’s a Stetsom EX10500EQ
Someone had the wrong outputs in the amp and all of them were defective along with the driver IC’S (IR2110S)
At one point in time it appears these logic gate ic’s were replaced and they just did a bad job at soldering them in so I removed the from the board and cleaned up the board and pads .
So was wondering since I removed them from the board and who knows how much heat was applied when they replaced them if they could be easily damaged and I should replace them
