Digital Deaigns M4A
Digital Deaigns M4A
Old 19th October 2020, 06:27 AM   #31
Perry Babin is offline Perry Babin  United States
Which end of D82 reads 0 ohms to the negative rail?
Remove C83 and see if the gate voltage changes.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 19th October 2020, 06:37 AM   #32
caraudioguy2100 is offline caraudioguy2100
Striped side of D82 has 0 ohms to the negative rail
And if I remove C83 I get -3.90 volts on the gate
Old 19th October 2020, 06:42 AM   #33
Install another cap there to see what the voltage goes to.
Was the positive terminal connected to the negative rail?
Old 19th October 2020, 06:51 AM   #34
New cap and the voltage is at -4.70 volts black probe on negative rail.
Old 19th October 2020, 07:01 AM   #35
Have you given up on finding a K30A?
The diode D82 is a 5v Zener. That's limiting the gate voltage to -4.7v. That may not be enough to get a J111 to switch off. Replacing that diode with a 10vZ and installing the J111 with the correct pin configuration (don't let the leads short) may allow it to work.
If you try it and it doesn't work, post the DC voltage on all 3 terminals of the J111.
Old 19th October 2020, 07:03 AM   #36
Can’t find a K30A
I’m am not a fan of using NTE parts but the local shop has a nte cross for the transistor
Wondering what your thoughts are on this ?
Old 19th October 2020, 07:05 AM   #37
It could be an option.
Old 19th October 2020, 07:30 AM   #38
I looked through my junk boards and what are the odds I found a K30A in an old kenwood amp .
Replaced it and amp has audio .
Thanks for helping me with this repair greatly appreciate it
Old 19th October 2020, 07:39 AM   #39
That may be useful. The 2SK30A may be available from pacparts or east coast transistor as JVC or Kenwood parts.
  Reply to this post
Digital Deaigns M4AHide this!Advertise here!
Tpa3118 and digital noise if digital (with dsp) preamp shares power supply 777funk Class D 7 29th March 2020 01:09 PM
Converting Toslink Digital in to a Coaxial SPDIF Digital Input on Theta DAC dtm1962 Digital Line Level 1 15th June 2018 07:12 PM
Digital audio input for a a digital class D amplifier asenapati Digital Source 80 14th June 2016 05:32 AM
Digital Crossover/DSP for active speaker with analog and digital input? Guitarfreak Digital Line Level 4 16th July 2013 06:46 AM
PC based digital crossover with dolby digital live preiter PC Based 64 25th April 2012 08:14 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
