Anyone know the value of R131,231 ? Board number : P200 RevB
C caraudioguy2100 Member Joined 2010 2020-10-11 6:55 am #1 2020-10-11 6:55 am #1 Anyone know the value of R131,231 ? Board number : P200 RevB ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2020-10-11 7:13 am #2 2020-10-11 7:13 am #2 The PC# is 0004B The resistors are 220 ohms. ••• More options Share C caraudioguy2100 Member Joined 2010 2020-10-13 4:43 am #3 2020-10-13 4:43 am #3 What drives the power supply gets in this amp ? Are they run off the 594 or is it 2 npn transistors the MMBT2222 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2020-10-13 5:27 am #4 2020-10-13 5:27 am #4 It's the same as other Rockford amps. EF pairs but they're on the PS driver board. ••• More options Share C caraudioguy2100 Member Joined 2010 2020-10-13 5:38 am #5 2020-10-13 5:38 am #5 So the transistors marked 1B and 3B are the power supply drivers ? And can I use 56/06 for replacements Attachments 80626F9D-86C1-4E3F-B7A6-CC19305203EA.jpg 1.2 MB · Views: 74 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2020-10-13 5:44 am #6 2020-10-13 5:44 am #6 It should be the four transistors in the lower left corner, driving terminals 1 and 2 of the driver board. ••• More options Share C caraudioguy2100 Member Joined 2010 2020-10-13 5:51 am #7 2020-10-13 5:51 am #7 They are marked 1B and 3B Can I use the the MMBTA06 for the 1B’S And MMBTA56 for the 3B’S? ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2020-10-13 5:56 am #8 2020-10-13 5:56 am #8 Yes ••• More options Share C caraudioguy2100 Member Joined 2010 2020-10-20 6:43 am #9 2020-10-20 6:43 am #9 The driver transistors for the power supply are marked 1B and 3B Are the 3B’S npn or pnp ? Just wondering this cause with just power and ground the amp will draw excessive current ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2020-10-20 6:57 am #10 2020-10-20 6:57 am #10 The collector of the PNP connects to ground. 3B = PNP. ••• More options Share C caraudioguy2100 Member Joined 2010 2020-10-21 2:30 am #11 2020-10-21 2:30 am #11 Do you happen to know what ones are the drivers for the outputs ? Attachments C5F47732-636E-4B60-834A-8F6BC5A36A29.jpg 1.1 MB · Views: 44 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2020-10-21 2:48 am #12 2020-10-21 2:48 am #12 I'd recommend that you contact seankane and buy new driver boards for the audio. ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link Home General Interest Car Audio Rockford Fosgate Punch 200DSM Top Bottom
