Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
Anyone have any pics of the board ?
Or might be able to tell me the value of the resistors ? |
#2 |
In the power supply, is that resistor between the primary and secondary grounds?
In the audio circuit, the photos I have, have the same resistor burned, but not as badly. I don't know if the multiplier band is reliable. Does it connect between the shield ground and the secondary ground?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version. |
#3 |
The resistor in the power supply connects between primary and secondary ground
The resistor that is burned connects to the shield ground of the rca and the secondary ground |
#4 |
A 1k in the power supply should work.
The color bands in the photo I posted may be right.
#5 |
Back to this amp .
Replaced the resistors amp powers up and had audio but the left channel has very low output . Any ideas on where to start looking ? I cleaned all switches and it made no difference |
#6 |
The preamp signal for both channels should be equal on the inter-board header. Are they equal?
#7 |
Yes they are equal
#8 |
What are the part numbers on Q131/231?
Does one terminal connect do the secondary ground?
#9 |
D1302
And yes one of its terminals connects to secondary ground |
#10 |
Pull them and see if the channels equalize.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Crossfire Amp | imraneesa | Car Audio | 5 | 14th September 2020 04:03 PM |
Help with Crossfire BMF 600.2 | kiermee | Car Audio | 20 | 23rd January 2017 05:17 PM |
Crossfire 360 Help | Tom Da Tech | Car Audio | 0 | 18th March 2012 04:35 AM |
Crossfire C3 704 | MarKart | Solid State | 0 | 24th January 2012 05:43 PM |
Crossfire amp help please cfa-602 | joesch1999 | Car Audio | 111 | 26th April 2011 03:56 AM |
New To Site? | Need Help? |
