Cerwin Vega Vega 3204
Old 13th September 2020, 02:22 AM   #11
caraudioguy2100 is offline caraudioguy2100
Nothing has changed .
I was using amps ground terminal as ground reference at first so I had 2 volts on pins 1,2,3,5,6,7 of the opamps .
If I use the secondary ground all voltages are correct and pins 1,2,3,5,6,7 remain at 0.00 volts
Old 13th September 2020, 03:00 AM   #12
Perry Babin is offline Perry Babin  United States
It's normal for regulators to get hot.
Some amps have an isolated secondary which prevents measuring voltage using the primary ground.
From the information that you've provided, I don't know why the +15v would be the only missing voltage when measuring the voltage using the primary ground.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 16th September 2020, 03:10 AM   #13
Back to this amp once again .
I replaced the positive regulator and an opamp .
Now this amp lokes to burn up the transistor and resistor connected to pin 8,11,12 of the 494 Itís burnt up twice now
Any ideas why this keeps happening
File Type: jpg 92283A7D-81C3-47A4-90FD-ACA8EC1B558D.jpg (992.8 KB, 15 views)
Old 16th September 2020, 03:19 AM   #14
Never mind I figured out why it keeps burning
Old 16th September 2020, 04:18 AM   #15
Ok got a question .
The power light on this amp consists of 5 light bulbs the originals looked like incandescent light bulbs . They were all burnt out .
I swapped them over to leds and now get the transistor that controls the 13 volts to pin 8,11,12 of the 494 to burn and blow apart .
Could switching the incandescent bulbs over to leds cause this issue ?
Old 16th September 2020, 04:30 AM   #16
Sure if you didn't include a current limiting resistor.
  Reply to this post
Cerwin Vega Vega 3204Hide this!Advertise here!
Wanted Australia only. Cerwin Vega Vega 154 Moondog55 Swap Meet 1 12th October 2019 08:52 PM
Cerwin Vega D3 ? bthp223 Multi-Way 6 25th January 2017 05:02 PM
Cerwin Vega Amp mike49504 Car Audio 8 29th August 2011 07:39 AM
lw-12 cerwin vega irishguy170 Subwoofers 2 30th January 2010 01:16 AM
Cerwin Vega VSW-12 layertone Subwoofers 2 23rd November 2005 02:21 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
