Rockford Fosgate Punch 600a4
Thread Tools
Old 1st October 2020, 05:05 AM   #71
Perry Babin is offline Perry Babin  United States
What, specifically, do they think is wrong?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 1st October 2020, 06:22 AM   #72
objext is offline objext  United States
One person thinks the regulators should be running at exactly equal & opposite voltages. Another person thinks one is being loaded higher than the other, and that there is a problem with the "imbalance of voltage of nearly 2 volts.". One of them I believe is fairly knowledgeable/respected, the other I don't know as well. Neither seem to have much time to go back and forth about it, which I understand.
Old 1st October 2020, 07:10 AM   #73
They should have explained how the regulators work.
As with op-amps or comparators, they use a reference voltage and adjust according to that reference. For these regulators, they are designed to have a 1.25v difference between the output and adjust terminals. They do all they can to maintain that 1.25v difference. Older regulators or lower quality regs will vary more than the 1.25v. The precise offset isn't very important unless you have a circuit where voltage is critical (it absolutely is not for this application).
The two 'programming' resistors are also a factor. The resistors have a tolerance and sometimes drift in value. These make a difference in the way they divide the voltage and therefore affect the final voltage.
If you have the repair tutorial, item #25 on the Audio TroubleShooting page goes into more detail as well as gives a calculator to see how the various components affect the output voltage.
Old 5th October 2020, 06:48 AM   #74
Originally Posted by Perry Babin View Post
Are the waveforms for the power supply gate drive identical on both banks?
You can check without B+ connected.
The wine could simply be the regulator for the rails. If so, it's not a problem.
Dies reducing the bias reduce the drop across the Rx70/Rx71 resistors?
I went ahead with swapping the power supply caps and both regulators for piece of mind (aka glutton for punishment).
Turning the bias pots fully ccw made no change to the voltage drop across any of the Rx70/Rx71 resistors.
Even with the bias fully ccw, the regulators heat the same - 221F for the LM317, 209F for the LM337, 72F ambient temperature.
Reset the bias via current draw method, starting at .98A idle and turning up bias pots individually for .05A rise, ending at 1.18A idle. Regulators maintaining same temperature.
Old 5th October 2020, 09:54 AM   #75
Do you still believe that there is a problem?
Old 5th October 2020, 06:46 PM   #76
A fault, maybe not, but I still think it's a problem to get hot enough to damage the PCB. I will reach out and see if anyone else has the same model and can check the temps.
Old 5th October 2020, 07:31 PM   #77
I've seen regulator damage to the boards on home receivers that cost $2k. You saw it on another rockford amp that was in a much cooler environment.
  Reply to this post
Rockford Fosgate Punch 600a4Hide this!Advertise here!
Thread Tools
Rockford punch 600a4 rhempz01 Car Audio 20 26th June 2018 11:47 PM
Rockford Fosgate Punch 45 not HD Life is an Enigma Car Audio 4 7th January 2018 11:18 PM
Rockford Fosgate 600a4 S Merlington Car Audio 4 3rd February 2016 04:41 AM
Rockford Fosgate 600A4 S Merlington Car Audio 3 29th August 2015 06:48 AM
Rockford Fosgate Punch 160.2 S Merlington Car Audio 5 27th August 2013 01:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
