Rockford Fosgate Punch 600a4
Thread Tools
Old 29th August 2020, 03:52 AM   #11
Perry Babin is offline Perry Babin  United States
What's the rail voltage?
Is it regulating when you increase the 12v supply voltage?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 29th August 2020, 04:37 AM   #12
objext is offline objext  United States
Looks like I am getting 29.04V for rail voltage. My power supply is not great - it's not variable and looks like it's only putting out 11.46V with the current 1.39A idle load.
Old 30th August 2020, 11:57 PM   #13
Pulled the board and reworked the transformer down to a reasonable position. Also noted the heat discoloration on the board from the U3 LM317.
Filter caps all read ~400ohm and then gain up beyond 2000+ on either my meter's 2000ohm setting or diode mode.
Old 31st August 2020, 12:34 AM   #14
Level the cap with the heatshrink that's pulled up and put a drop of adhesive under the points that would touch the board if the cap was pushed to the side.
Old 31st August 2020, 12:50 AM   #15
Good idea. Hot glue perhaps? Any other thoughts on the LM317 heat?
Old 31st August 2020, 01:17 AM   #16
Never use hot glue. Use something like goop, e6000 or even silicone. All you need is a tiny dot on opposite sides.
I'd expect the regulators to run hot but I don't know what's normal.
What's the DC voltage on terminals 1 and 2 of the 494?
Old 31st August 2020, 05:07 AM   #17
TL494C voltages to B- are:
Pin1: 2.22
Pin2: 2.22
Pin3: 1.54
Pin4: 0.10
Pin5: 1.47
Pin6: 3.26
Pin7: 0.00
Pin8: 13.52
Pin9: 4.52
Pin10: 4.50
Pin11: 13.51
Pin12: 13.52
Pin13: 4.84
Pin14: 4.84
Pin15: 4.84
Pin16: 0.00
Old 2nd September 2020, 05:55 AM   #18
Is it strange that pin1 and pin2 are the same voltage? Would failed/failing electrolytic caps cause this issue with heat? I get mixed results/opinions on whether to recap amps that don't show leakage or swelling...
Old 2nd September 2020, 06:09 AM   #19
The same voltage on pins 1 and 2 indicates that the regulation of the rail voltage is working properly.
The majority of the large capacitors on the B+ or the rails are used to filter high frequency (in the neighborhood of 30kHz) ripple. With a scope, you can get a very good indication of whether the caps are good enough by looking at the ripple on the rail and B+ voltage. It's normal to see ripple that's related to the frequency of audio. The problem is when you see high frequency ripple along with the audio related ripple. This can be very difficult to see on digital scopes. On analog, CRT scopes, it's immediately obvious.
Old 11th September 2020, 06:54 AM   #20
I picked up a power supply with some voltage adjustment. Regulation holds 29.04V from 12V to 14.4V. The 317 & 337 seem to get equally hot at either end of that range.
Rockford Fosgate Punch 600a4Hide this!Advertise here!
Thread Tools
Rockford punch 600a4 rhempz01 Car Audio 20 26th June 2018 11:47 PM
Rockford Fosgate Punch 45 not HD Life is an Enigma Car Audio 4 7th January 2018 11:18 PM
Rockford Fosgate 600a4 S Merlington Car Audio 4 3rd February 2016 04:41 AM
Rockford Fosgate 600A4 S Merlington Car Audio 3 29th August 2015 06:48 AM
Rockford Fosgate Punch 160.2 S Merlington Car Audio 5 27th August 2013 01:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
