You should know by now that photos are critically important since there are many similar amps. It may or may not help but it takes seconds to include and couldn't hurt to post.
If this is a ZED amp. I'd guess that the original components were a 0.1uF cap and a 2.7 ohm resistor. For the Zobel resistors, I've see some OEM resistors that didn't match the silkscreen.
I don't know what they're using for a drive circuit but unless they're using a lot of deadtime, I think you'll have to reduce the gate resistor value to something more common (47 ohms). If the drive circuit is weak (photos?), you may need to do more to use the 3205s.
